Hi Blynkers - I’ve been using the Blynk IoT app (version 1.28) on my ipad at home (Germany) without problem. When trying to launch the app here in Portugal it wont accept my password. I guess I could reset my password - but is there a simpler solution?
Thanks.
Hello, use old app version. Please download from App Store last iOS Blynk IoT app.
Thank you for quick response. I am using Blynk IoT version 1.28 which is the latest version on the app store.
Last version should be 3.5.4 (0).
Please provide a screenshot from About page in app
@Oleksii-QA He can’t get to the about page in the app, because he can’t get past the login screen.
The iOS App Store shows an Apple allocated version number, which is 1.28
I have this installed and in the app it shows as 3.5.4 (0)
Thanks Pete, exactly right. Can’t get past the log in screen.
@Aggertroll are you sure you’ve not had a few too many glasses of the local vino? It’s strong stuff you know!
@Aggertroll Checked your subscription. Your original server at registration is fra1. Perhaps from Portugal you are connected to the London server. Do you only have one account on the servers?
I have only one account. I can log in via the browser interface no problem.
Tell you what: don’t worry about it for my sake. I thought there might be a simple reason. We’ll see if it fixes itself when I am back bome.
Hi @Aggertroll
Thank you for the report. If you could send us app logs it would help us investigate the issue. To send logs:
- quit the Blynk IoT App
- go to system Settings app, find Blynk there and enable logging
- launch Blynk IoT app and try to login
- go back to initial app screen, tap&hold on the Blynk logo there. The About screen will appear.
- from About screen tap Send Logs. Type a quick note what the issue is about.
I did exactly as you said, you should receive my email.
The app usually connects to fra1.blynk.cloud.
About screen says Version 3.5.4 (0), Account - , Server (null)() .
Do you see the letter in your Sent? Cause I don’t see it in our Inbox…
Gmail returned the email saying it was missing a SPF or DKIM certification. So I sent the log file to hello@blynk.cc instead. You should find it there. Sorry for the difficulties.
Thanks for report. Should be fixed now.
Wow, you are awesome! Works. Thanks, and all the best.
