[SOLVED] https://localhost:7443/admin not working?
Am I missing something?
My server.properties
allowed.administrator.ips=127.0.0.1,192.168.1.3
Local ip works, access is given by
http://192.168.1.3:7443/admin
but not
http://localhost:7443/admin
nor
http://127.0.0.1:7443/admin
also is there a way to allow all IP’s on my LAN?
192.168.1.* or similar?
#comma separated list of administrator IPs. allow access to admin UI only for those IPs.
#you may set it for 0.0.0.0/0 to allow access for all.
#you may use CIDR notation. For instance, 192.168.0.53/24
allowed.administrator.ips=0.0.0.0/0
It also should be https only.
Minor miss on my part with the S, I did try with https, just didn’t write it here :slight_smile:
I tried with CIDR addr.
192.168.1.3/32
No dice on making it accessible from any PC. My dhcp pool is 3-50´
Do I need all of the ones generated below or just 1? Haven’t read in depth how CIDR works :stuck_out_tongue:
And I have still yet to figure out why localhost does not work ^^
Try the suggestion from @Jamin that should work. The 0.0.0.0/0 notation allows all IP’s. Localhost is only from when you access the blynk server with IP 127.0.0.1 (which is kind of a weird IP address).
Are you actually running the blynk server on the same machine you try to access the admin page from? Because I couldn’t make that out in your message.
Hio,
But does this mean that any IP from outside my LAN can access the admin page should I choose to or accidentally open up the 7443 port ?
Yes I am testing it on 2 PCS, the one that runs the server and another one.
No, not unless you forward ports. No one can access your local network from outside, unless you configure that on your modem, router or firewall.
And the fact that you are running the server on a different machine explains why you cannot reach it with 127.0.0.1. This is ALWAYS the local address of the local machine, you cannot use this for remote access.
You need all of them to cover .1.3 to .1.50. Separate them with commas as per the note in server.properties.
It did the trick thank you!
