Been trying a variety of different approaches to do a countdown, but am struggling a bit…
Whats the best way to do a countdown? Any suggestion or help would be greatly appreciated.
Scenario:
User press’ a start button.
The countdown should be for 1 hour.
Display a percentage or time left (59 minutes ramining, etc.)
At the end of the hour, turn on an LED
Thanks @Dave1829 but I am trying to do it all in BLYNK using a Photon.
I was able to achieve a simple version with the Arduino101 but wanting to do it using a Photon.
As Pavel said… not really Blynk related but I’m going to try and help.
@jhey, study the following code and make it fit your project. … and maybe this will come in handy for other people.
#include <ArduinoOTA.h>
char auth[] = "xxxxxxxx";
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxxxx";
int CountdownRemainReset;
int CountdownRemain;
int CountdownTimer;
WiFi.mode(WIFI_STA);
while (Blynk.connect() == false) {}
ArduinoOTA.setHostname("Countdowner"); // OPTIONAL
ArduinoOTA.begin();
CountdownTimer = timer.setInterval(1000, CountdownTimerFunction);
timer.disable(CountdownTimer); // disable it on boot
void CountdownTimerFunction() {
CountdownRemain--; // remove 1 every second
CountdownShowFormatted(CountdownRemain);
if (!CountdownRemain) { // check if CountdownRemain == 0/FALSE/LOW
timer.disable(CountdownTimer); // if 0 stop timer
Blynk.virtualWrite(1, LOW); // reset START/STOP button status
Blynk.virtualWrite(0, "TIMER COMPLETE");
Blynk.virtualWrite(6, 255); // LED for timer completed
Blynk.virtualWrite(5, 0); // Timer LED status light off
Blynk.virtualWrite(6, 0); // LED for timer completed
// Button Widget (Switch Type): Start/Pause Timer
BLYNK_WRITE(1) {
if (param.asInt()) {
if (CountdownRemain) { // check if there is a time set or not
timer.enable(CountdownTimer);
Blynk.virtualWrite(5, 255); // Timer LED status light on
Blynk.virtualWrite(1, LOW); // if CountdownRemain is set to 0, then dont start hte timer.
Blynk.virtualWrite(0, "COUNTDOWN TIME NOT SET"); // if CountdownRemain is set to 0, then tell the user
// Button Widget (Momentary): Reset Timer
BLYNK_WRITE(2) {
CountdownRemain = CountdownRemainReset; // reset to original start time
// Slider Widget (60-180): Set Timer (mins)
BLYNK_WRITE(3) {
if (timer.isEnabled(CountdownTimer)) { // only update if timer not running
Blynk.virtualWrite(3, param.asInt() ); // if running, refuse to let use change slider
CountdownRemainReset = param.asInt() * 60 + 1; // + 1 set the timer to 1:00:00 instead of 00:59:59
CountdownRemain = param.asInt() * 60;
void CountdownShowFormatted(int seconds) {
long days = 0;
long hours = 0;
long mins = 0;
long secs = 0;
String secs_o = ":";
String mins_o = ":";
String hours_o = ":";
secs = seconds; // set the seconds remaining
mins = secs / 60; //convert seconds to minutes
hours = mins / 60; //convert minutes to hours
days = hours / 24; //convert hours to days
secs = secs - (mins * 60); //subtract the coverted seconds to minutes in order to display 59 secs max
mins = mins - (hours * 60); //subtract the coverted minutes to hours in order to display 59 minutes max
hours = hours - (days * 24); //subtract the coverted hours to days in order to display 23 hours max
if (secs < 10) {
secs_o = ":0";
if (mins < 10) {
mins_o = ":0";
if (hours < 10) {
hours_o = ":0";
Blynk.virtualWrite(0, days + hours_o + hours + mins_o + mins + secs_o + secs);
ArduinoOTA.handle();
Personally I would have ceased all assistance after this statement… and I usually go out of my way to write some code for someone in need, but they have to seem to try first.
@Jamin Thank you for your efforts here… as Yes, others like myself appreciate it. I am self taught, by example first, then following up with study, in most everything I do. Having code snippets like this to dissect really help!
I felt the same… but I know from experience and trawling through hundreds of useless forums posts where no one else helps… that I felt I had to help since I knew the answer.
The above example is probably a bit messy. If I had an hour to re-write it I would… but it serves the purpose
Here is an additional bit of code for working out the overall progress dynamically.
// Get the progress (0-100%)
void CountdownProgress(int seconds){
int progress = map(seconds,CountdownRemainReset,0,0,100); // make sure to invert it
Blynk.virtualWrite(4,progress + String("%"));
Then update the following function from above:
CountdownProgress(CountdownRemain);
@Gunner thanks for your comments. I am here seeking help, after spending many hours working on it.That response was to @Pavlo 's comment.
If I had it working, I would not be asking for suggestions. Glad I found someone (@Jamin) willing to provide a valuable response, as opposed to negative feedback.
I will continue to work on the code and share my findings here and the tutorial I am trying to write:
Negative feedback often has a positive purpose, and is essential in both electronics and real life… without it things may just sit around and wait for something else to do the work.
I have to agree. I take all negitivity as constructive criticism.
Gunner is a valued community member and he (and I) see many people ask silly questions… often unrelated to Blynk… so its easy to skip over it without helping.
Hello. I have installed your code, but I have a problem. When power is cut off, it does not resume where it left off. Could you generate a code for this with help from EEPROM? happy event if you help.
Each EEPROM memory location has a limited write capacity before that location “burns out”. Constantly writing to a location to store the latest countdown value would kill your EEPROM pretty quickly.
You’d be better-off writing Tha value to the Blynk cloud server then syncing it back to your device when it powers back up.
