I’m trying to port this code to Blynk where the goal is to run the stepper motor when Button(V1) is pressed:
#include <AccelStepper.h>
#define HALFSTEP 8
// Motor pin definitions
#define motorPin1 D5 // IN1 on the ULN2003 driver 1
#define motorPin2 D6 // IN2 on the ULN2003 driver 1
#define motorPin3 D7 // IN3 on the ULN2003 driver 1
#define motorPin4 D8 // IN4 on the ULN2003 driver 1
// Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
stepper1.setMaxSpeed(1000.0);
stepper1.setAcceleration(100.0);
stepper1.setSpeed(200);
stepper1.moveTo(20000);
}//--(end setup )---
//Change direction when the stepper reaches the target position
if (stepper1.distanceToGo() == 0) {
stepper1.moveTo(-stepper1.currentPosition());
stepper1.run();
Here’s my Blynk code:
#define HALFSTEP 8
char auth[] = "********";
char ssid[] = "********";
char pass[] = "********";
stepper1.moveTo(-999999);
BLYNK_WRITE(1)
stepper1.run();
So far, when the button is pressed on or off, the motor is moving one step at a time. So, for 200,000 steps, I’d be pressing to 200,000 times. What’s the right way to do this instead of having to manually press the button 200,000 times?
EDIT:
After some more investigation, BLYNK_WRITE(1) is invoked every time the blynk button is pressed ON or OFF. This calls the “stepper1.runSpeed()” which returns a boolean vale “true”. This causes the motor to go 1 step. Still not sure how I can keep it moving continuously when the blynk button is pressed.
