Yes, Im using gmail email with same username and password.
this are the logs from the server:
From blynk logs:
02:35:52.843 INFO - Using data dir ‘\path’
02:35:53.202 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
02:35:53.530 INFO - Plain tcp/ip hardware server port 8442.
02:35:53.530 INFO - Enabling SSL for hardware.
02:35:53.530 WARN - ATTENTION. Certificate C:\Users\Jun\Blynk\Server and key C:\Users\Jun\Blynk\Server paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
02:35:53.984 INFO - SSL hardware port 8441.
02:35:53.984 INFO - Enabling SSL for application.
02:35:53.984 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Jun\Blynk\Server’, key : ‘C:\Users\Jun\Blynk\Server’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
02:35:54.249 INFO - Application server port 8443.
02:35:54.265 INFO - Enabling HTTP API.
02:35:54.265 INFO - HTTP API port 8080.
02:35:54.265 INFO - Enabling HTTPS API.
02:35:54.265 WARN - ATTENTION. Certificate C:\Users\Jun\Blynk\Server and key C:\Users\Jun\Blynk\Server paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
02:35:54.406 INFO - HTTPS API port 9443.
02:35:54.421 INFO - Enabling HTTPS for admin UI.
02:35:54.421 WARN - ATTENTION. Certificate C:\Users\Jun\Blynk\Server and key C:\Users\Jun\Blynk\Server paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
02:35:54.693 INFO - HTTPS admin UI port 7443.
02:35:54.693 INFO - Enabling Web Sockets.
02:35:54.693 INFO - Web Sockets port 8082.
02:35:54.693 INFO - Enabling Web SSL Sockets.
02:35:54.693 WARN - ATTENTION. Certificate C:\Users\Jun\Blynk\Server and key C:\Users\Jun\Blynk\Server paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
02:35:54.959 INFO - Web SSL Sockets port 8081.
08:41:18.363 INFO - junxxxxx@gmail.com app joined.
from the user logs:
09:18:59.883 INFO - Generated token for user junxxx@gmail.com and dashId 1 is 4d0548bc3ffd40ed80e64c3182e623c0.
15:58:23.924 INFO - Creating new dashboard.
15:58:23.955 INFO - Generated token for user junxxx@gmail.com and dashId 2 is e6c33e8bfd9e457883f7e3477645551a.
15:58:34.887 INFO - Deleting dashboard 2.
15:58:49.701 ERROR - Error performing blocking IO. 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/answer/14257 m6sm12838288wje.21 - gsmtp
15:58:56.014 ERROR - Error performing blocking IO. 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/answer/14257 n10sm12845960wjf.28 - gsmtp
16:04:05.132 ERROR - Error performing blocking IO. 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/answer/14257 74sm8620465wmn.17 - gsmtp
16:04:05.163 ERROR - Error performing blocking IO. 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/answer/14257 s66sm8669115wmb.6 - gsmtp
