* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use Arduino Ethernet shield (W5100)
* to connect your project to Blynk.
* Feel free to apply it to any other example. It's simple!
* NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
* DON'T use them in your sketch directly!
#define BLYNK_DEBUG
#include <Ethernet.h>
char auth[] = "xxx";
//Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, "your_server.com", 8442);
Blynk.begin(auth, IPAddress(192,168,0,177), 8442);
and
* This example shows how to configure static IP with Ethernet.
* Be sure to check ordinary Ethernet example first!!!
IPAddress server_ip (192, 168, 0, 1);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip (192, 168, 0, 177);
IPAddress dns_ip (192, 168, 0, 1);
IPAddress gateway_ip (192, 168, 0, 1);
IPAddress subnet_mask(255, 255, 255, 0);
Blynk.begin(auth, server_ip, 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
// Or like this:
//Blynk.begin(auth, "blynk-cloud.com", 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
