[SOLVED] Hardware doesn't connect
The same applies for me as for the most of you other guys.
My app is now connected so that part is working.
But my Arduino will not connect to the servers.
I do have the latest library (V.0.3.4). I attached a print screen on my serial where the Arduino tries to connect.
Should also be noted that the Arduino have access to internet through a ESP8266 which do show on my router so that is not the problem either.
Everything has work perfect before this change of server.
Any ideas please?
Problem solved, library 0.3.5 solved it!
not for everyone. I have version 3.5 on my particle electron, and it still doesn’t work. It says it is not in network. I’ve tried refreshing token as well.
Sorry to here that. Unfortunately I have no experience of that device, I am on Arduino only.
Hope the developer fix this soon!
Actually more likely to be your ISP dns not updated if all of your hardware is properly updated… I had to manually set my dns to the google one 8.8.8.8 to get it working…
0.3.7 is the latest. please check it. Is the issue solved?
Yes my problem is solved! Updated to a library I thought was the latest but no… Maybe it should be on your first page a link to the latest library or something like that?
But anyhow, when I got the real latest it worked.
My electron is cellular. Are you saying it’s the cellular provider? I verified connected to the cloud but blynk says out of network
