Hi friends.
is anyway to use eventor with analog pin on Nodemcu ? in eventor there is no analog pin selector.
You need to use virtual pins and coding with analogRead()
Iām adding below code to my project but itās wrong on compilig
BLYNK_READ(V5) //Blynk app has something on V5
sensorData = analogRead(A0); //reading the sensor on A0
Blynk.virtualWrite(V5, sensorData); //sending to Blynk
the full sketch
#include <SimpleTimer.h> // Allows us to call functions without putting them in loop()
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // Your ESP8266 pin (ESP9266 GPIO 2 = WeMos D1 Mini pin D4)
char auth[] = "e926e5e00df34563a62ab2377f640732";
char ssid[] = "";
char pass[] = "10242048";
char server[] = "";
int roomTemperature; // Room temperature in C
Blynk.begin(auth, ssid, pass, server);
// Wait until connected
sensors.begin(); // Starts the DS18B20 sensor(s).
sensors.setResolution(10); // More on resolution: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
timer.setInterval(2000L, sendTemps); // Temperature sensor read interval. 2000 (ms) = 2 seconds.
// Notice how there is very little in the loop()? Blynk works best that way.
// Notice how there are no delays in the function below? Blynk works best that way.
void sendTemps()
sensors.requestTemperatures(); // Polls the sensors.
roomTemperature = sensors.getTempCByIndex(0); // Stores temperature. Change to getTempCByIndex(0) for celcius.
Blynk.virtualWrite(1, roomTemperature); // Send temperature to Blynk app virtual pin 1.
You didnāt show the compile error, but you do need to assign this variable as an integer or something⦠standard āArduinoā Programming 101. https://www.arduino.cc/en/Reference/VariableDeclaration
int sensorData = analogRead(A0); //reading the sensor on A0
Ok. I changed it to
inputVariable2 = analogRead(A0); //reading the sensor on A0
Blynk.virtualWrite(V5, inputVariable2); //sending to Blynk
the compiling error:
sketch_jul14a:19: error: 'inputVariable2' was not declared in this scope
You only changed the variable name and ignored the need to declare it (and I even gave you the correct answer in my previous post) ⦠Please read up on the Arduino site (link above) for programming tips and references⦠Teaching you how to program is NOT the scope of this forum!
Your OP question has been answered, so I am marking this topic as solved.
Ok. I reading your link fully and adding the codes:
error is:
sketch_jul14a:54: error: āvoid A0()ā redeclared as different kind of symbol
void A0()
#define analogPin A0
char ssid[] = "";
char pass[] = "";
char server[] = "t";
int analog = 0;
timer.setInterval(2000L, analog); // Temperature sensor read interval. 2000 (ms) = 2 seconds.
void sendTemps()
void A0()
analog= analogRead(analogPin); // analog read on A0
Blynk.virtualWrite(12, analog); //displays analog data on V12
You can NOT use a pin designation as a void name⦠Please start reading the error messages and making some intelligent guesses as to their meaning. Even Googling the error message will often help.
Pleas refer any further NON Blynk, Arduino programming type, questions over on the Arduino Forum. Thank you. https://forum.arduino.cc/
