Hey guys,
first of all, I want to say that I was searching the forum for similar problems (like: here ) but I just cannot get it to work properly.
Since I am new to all this, I followed this instruction to set up my ESP8266 as a Wifi Shield to use it with blynk.
As in the instruction I have an Arduino Uno and the ESP8266.
I can control any Digital Output of my Board via the Blynk App (e.g. the LED at D13 with a Button). But I cannot use the Virtual Pins. Either I have a mistake in my Code or something is wrong with my software/ hardware setup.
Here is my Code (please be aware that I use the 0.3.4 library as in the instructions, because I didn’t manage to get it run with the 0.3.7 - neither hardware nor software serial). In order to test the Virtual Pins, I want to control a LED connected to Digital 2.
//#define BLYNK_DEBUG
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
#define EspSerial Serial
ESP8266 wifi(EspSerial);
char auth[] = "###";
int vvalue; //global value for blynk widget
pinMode(2,OUTPUT);
EspSerial.begin(115200);
Blynk.begin(auth, wifi, "KDG-7B24B", "###");
BLYNK_WRITE(V1)
vvalue = param.asInt();
if (vvalue)
digitalWrite(2,HIGH);
digitalWrite(2,LOW);
I tried the getData example, but it does not display anything in my Serial Monitor. It always just shows these information:
[19] Blynk v0.3.4
[520] Connecting to KDG-7B24B
ATE0
AT+CWMODE?
AT+CWJAP="KDG-7B24B","###"
AT+CIFSR
[5576] IP: +CIFSR:STAIP,"192.168.0.208"
+CIFSR:STAMAC,"###"
OK
AT+CIPMUX=0
[5598] Connected to WiFi
AT+CIPCLOSE
AT+CIPSTART="TCP","blynk-cloud.com",8442
AT+CIPSEND=37
###[10749] Ready (ping: 13ms).
AT+CIPSEND=5
After that it just keeps sending AT+CIPSEND=5 every couple of seconds.
I have a project with a Button to Virtual Pin V1. But nothing happens when I press it. My button with LED13 still works tho.
Before you answer, please consider that I am new to this and try to make it as clear as possible. I really appreciate your help! Thank you so much!
PS: The wiring of the ESP8266 is also according to the instructions in the link above. Might the problem be there?
Thanks!!!
Chris
