help me!
ESP8266_Standalone.ino:28:25: fatal error: ESP8266WIFI.h: No such file or directory
compilation terminated.
help me!
Please follow instructions in the example code.
Use forum search. This question was answered many times already.
Please also select the right board from the menu…
I can not find esp8266wifi.h.
Where can I find it?
@smartinfo
Please follow instructions in the example sketch, you need to install ESP8266 support (or reinstall).
THEN SELECT the right board in Adtuino IDE menu. thanks.
Same problem. I have instaled https://github.com/esp8266/Arduino from comment… And stay compilator type
ESP8266_Standalone.ino:26:25: fatal error: ESP8266WiFi.h: No such file or directory
Please follow the instruction…
I find it and atache to project…but they stay in error.
had the same issue:
Make sure the ESPboard have been added (and installed) in your board manager (requires Arduino 1.6.3+) Select the GENERIC ESP8266 Module" as your board …
should work …
Gee, people really seem to be quite acid about this topic.
I have searched over 9 forums with no answer.
Here are my two cents.
The thing is that the library is called
ESP8266WiFi.h not ESP8266WIFI.h
Wasted 3 hours to find out this mistake.
