My Arduino code for the above post (unchanged from the example) is:
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use ESP8266 Shield via Hardware Serial
* (on Mega, Leonardo, Micro...) to connect your project to Blynk.
* Note: Ensure a stable serial connection to ESP8266!
* Firmware version 1.0.0 (AT v0.22) or later is needed.
* You can change ESP baud rate. Connect to AT console and call:
* AT+UART_DEF=115200,8,1,0,0
* Change WiFi ssid, pass, and Blynk auth token to run :)
* Feel free to apply it to any other example. It's simple!
//#define BLYNK_DEBUG
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
// Set ESP8266 Serial object
#define EspSerial Serial1
ESP8266 wifi(EspSerial);
// Set console baud rate
// Set ESP8266 baud rate
EspSerial.begin(115200);
Blynk.begin(auth, wifi, "ssid", "pass");
@joelrsails as @psoro points out you don’t have a Serial1 port on an Uno (Mega’s + Leonardo do) so it needs to be just Serial. You can ‘create’ another serial port by going down the soft serial route but it’s not recommended.
Sure enough, using the Software Serial Blynk example @ 9600 baud works great! Just had to use the “AT+CIOBAUD=9600” command to change the baud rate of the wifi chip.
