I’m using ESP8266 development board. It came with NodeMCU flashed. Using latest version Arduino IDE and necessary ESP8266 and Blynk libraries installed.
In IDE I selected NodeMCU as the board for port COM. Through IDE I’m able to flash my program. program runs and connects to Blynk cloud fine and I’m able to use widgets. I have customized functions working fine.
I connected 2 channel relay and connected 5v power, ground wires correctly. Also connected D1 and D2 to relay IN1 and IN2.
Through NodeMCU I can control D1 and D2 and the relay clicks.
– set pin index 1 to GPIO mode, and set the pin to high.
pin=1
gpio.mode(pin, gpio.OUTPUT)
gpio.write(pin, gpio.HIGH)
gpio.write(pin, gpio.LOW)
gpio.write(pin, gpio.IN)
But following code written in Ardunio flashed to the board is not working with relay.
Thanks Pavel for the reply. Yes I looked at that example. I’m using same functions to set HIGH and LOW on GPIO pins but some reason it’s not working.
What kind of relay do you use? Maybe there is a jumper missing to select if the relay should react on low or high input?
And why do you set the pin to input after your instructions?
#define WIFI_SSID "iHome"
#define WPA_PASSWORD "xxx"
// Auth Token for the Blynk App.
char auth[] = "xxx";
int DoorPin = 1;
//Time Object
//Set Door Pin to HIGH/LOW
BLYNK_WRITE(V1)
pinMode(DoorPin, OUTPUT);
if(digitalRead(DoorPin) == LOW)
digitalWrite(DoorPin, HIGH);
Serial.print("Pin set to HIGH");
digitalWrite(DoorPin, LOW);
Serial.print("Pin set to LOW");
pinMode(DoorPin, INPUT);
//Try reconnecting to Blynk
void reconnectBlynk()
if (!Blynk.connected())
if (Blynk.connect())
Serial.print("Blynk Reconnected");
Serial.print("Blynk Not reconnected");
Blynk.begin(auth, WIFI_SSID, WPA_PASSWORD); //insert here your SSID and password
while (Blynk.connect() == false)
// Wait until connected
Serial.print("Blynk Setup");
// Setup a function to do reconnection attempts once a minute
timer.setInterval(60000, reconnectBlynk);
// Initiates Blynk Connection
if (Blynk.connected())
I think I know these relays, I have a couple of those and they switch on with LOW and off with a HIGH signal. Have you tried “manually” controlling the relay’s by just putting a wire on them with +5v or GND? So, bypassing your programming and logic to see if the relays physically work?
I learned the hard way that pins numbers are differently addressed between NodeMCU and Arduino. In NodeMCU D1 and D2 can be referred as pin 1 and 2 but in Arduino we have to use actual GPIO numbers. For D1 GPIO address is 5 and for D2 GPIO 4…
