BLYNK
[SOLVED] ESP8266-12F cant connect to WIFI
Hi, guys,
i have a little problem with my new ESP-12
when i’m using the ESP8266-01,
i flash the firmware using AT22SDK,
and write this following sketch
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
  // to avoid delay() function!
Everything went well,
My esp-01 connected directly to my home Wifi and Blynk,
The problem happened when my esp-01 got burned, and i buy this new esp-12.
Everything looks good at first,
I flash it with the same AT22SDK, the ATcommand’s worked, I can send AT+CWMODE, Change CWMODE, Connect to AP, AT+CWLAP, AT+CWJAP, set esp-12 as AP, it’s all good,
But when i try to write it with the same Sketch, and reboot, the serial monitor stuck at
“[70]connecting to (myhomenetwork)”
, and no activity LED on my ESP-12,
it’s like it freezing when trying to connect to my home network,
What did i do wrong ? the wiring is
(ESP12 --- FTDI)
vcc --- 3,3v
grnd --- grnd
GPIO15 --- grnd
Rx ---- Tx
Tx --- Rx
CH_PD  ---- 3,3v
Has someone ever use this esp12 ?
Thx before.
First of all, you don’t need to flash the AT firmware. The Blynk sketch replaces it.
Must be the wiring then. Is the GPIO15 to gnd needed?
Thx for the reply,
I try to flash it to know that the module works fine, and it’s worked fine with the command to connect, or create AP,
but when i write the blynk sketch, it got stuck on connecting to wifi,
[70]connecting to (myhomewifi), and stop there.
from what i read, yes, the GPIO15 is connected to ground, i
t’s not working anyway, when i disconnected it.
Can you try rebooting your router? It could be the ARP table has issues with the mac address.
Wow, it worked !
Thank you so much, @Lichtsignaal
but i think, this esp-12 has weaker signal then the -01 before, because when i try to reboot, it’s like 3 out of 5 times, it won’t connect.
@ferrizall think you might be right. Whenever I use the nasty 01’s they trash all my WiFi connections in the immediate vicinity. I think Espressif noticed this and turned down the signal strength on later models.
yes, right…!
Oh, btw @Costas, while you here, maybe you can help me, since i burned out my esp-01 because i hooked it up directly to my motor driver input.,
so, now i’m using, the Logic level converter,
what i wanted to do is hooking up my GPIO2 and GPIO0 , to the in1, and in2 of my L298 motor driver,
the problem is my multimeter was lost, and i dont want to waste another esp8266 just because of the wrong wiring,
So, can you help me to wire this with Logic Level Converter thing?
I have independently 12v input to the L298 and independently 3.3 v input to my ESP.
Can i just wiring the GPIO to LV1 LLC and the motor in1 to HV1 LLC?
or
I still need other 5v and the 3.3v input added to the Logic Level Converter ?
sorry it’s a bit out of the topic that i created.
Create a new thread.
