I’ve got an ESP8266-01 (SDK 1.3.0.2 11 sep) and Arduino Mega 2560. I checked the ESP with serial, so it worked fine and was connecting to home net. Any way, I uploaded Blynk example for shield with HSerial.
Auth token, pass ssid. ESP connected successfuly but…
I used GP2 button on Android app and got no changes in GPO2 voltage level. I expected the led to blink but no change occured, it ramained HIGH 3.3V. Nevertheless, I noticed that blue led at ESP blinked every time I used GP2 button in app.
if you are using the ESP-01 as wifi shield you have no control over it , it’s used as slave communication through it.
so in Blynk App dashboard you should select your board as Arduino Mega , and you can blink the LED on pin 13
but you don’t have any thing to do in Pin 2 on ESP-01.
if you shared the code and Dashboard setup , it will be more clear and i can help you more.
I feel confused) Thank you for your remark. When I changed board to Arduino Mega it began to work just fine. Now I will go carefully through Blynk documentation as I should at the very beginning.
