Today I am connected (via SSH) to my linux server and I saw on the terminal the following errors:
Blynk Server successfully started.
All server output is stored in folder '/home/igor/blynk/./logs' file.
io.netty.handler.codec.DecoderException: javax.net.ssl.SSLException: Received fatal alert: unknown_ca
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:418)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:245)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:292)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:278)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:962)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:528)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:485)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:399)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:371)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112)
at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.net.ssl.SSLException: Received fatal alert: unknown_ca
at sun.security.ssl.Alerts.getSSLException(Alerts.java:208)
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1666)
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1634)
at sun.security.ssl.SSLEngineImpl.recvAlert(SSLEngineImpl.java:1800)
at sun.security.ssl.SSLEngineImpl.readRecord(SSLEngineImpl.java:1083)
at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:907)
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:781)
at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624)
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1098)
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:970)
at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:904)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:387)
... 12 more
This sequence of errors repeated 8 more times.
I got this error also with new version 0.16.2.
