@Imran123 Something to note… if you do have a USB-TTL adapter, then it will get it’s own port in the PC, but you CAN NOT use the IDE SM to view it, as the IDE SM will always grab the programming port (currently being used by the USB-link).
Using another terminal program like Termite will work in that case.
New progress
I have runned the following code and it run successfully
//#define BLYNK_PRINT SwSerial // ONLY AVAILABLE IF YOU HAVE A USB2TTL
//#include <SoftwareSerial.h> // ONLY AVAILABLE IF YOU HAVE A USB2TTL
//SoftwareSerial SwSerial(10, 11); // RX, TX ONLY AVAILABLE IF YOU HAVE A USB2TTL
char auth[] = "xxxxxxxxxxxx";
void myTimerEvent()
if(analogRead(A1>0))
Blynk.virtualWrite(V5, 255);
Blynk.virtualWrite(V5,0);
// Debug console ONLY AVAILABLE IF YOU HAVE A USB2TTL
//SwSerial.begin(9600);
Blynk.begin(Serial, auth);
hey #Costas#Imran123#Gunner …dudezz lov u a lott…My entire college students couldnt do this,even final yea studentz…but i made it with ua helpp…
Thanx a lot buddieeessss…
