I’m using the android app but it is not connecting at this very moment. It occasionally works but there seems to be an outage. Am I the only one? I’m in the UK by the way.
Hello. You are right. Seeing network issue in our DC.
Local server ftw!
Should be fine now.
Thanks! That was quick!
Do not load data history graph widget.
this is normal?
I’m actually having the same issue.
The widget started working as it should. Thank you!
