Hi, Blynkers.
My project must continue work offline if connection with Blynk server is losed. For this case in hardware board I use
RTC ds3231, which must be syncronised RTC widget. I wrote the test program for debuguding this variant. This program worked well, but after updating Blynk-library to v0.4.8 I cannot to syncronise ds3231 with RTC widget.
Here is my program:
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
#include <ESP8266mDNS.h>
#include <WiFiManager.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Wire.h>
#include "RTClib.h"
#define sda 2
#define scl 14
//#define eeprom_address 0x50 //Адрес устройства
int eeprom_address = 0x50;
WidgetRTC rtc;
WiFiManager wifi;
RTC_DS3231 Hrtc;
String ssid;
String pass;
int analogPin = 0;
int rssi;
bool scan_done = false;
bool isFirstConnect = false;
bool write_eeprom_done = false;
bool read_eeprom_done = false;
DateTime now_;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
char auth[] = "xxxxxxxxxxxxx";
unsigned int cur_moisture = 0;
void EEPROM_WriteByte(int dev, unsigned int eeaddress, byte data)
Wire.beginTransmission(dev);
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.write(data);
Wire.endTransmission();
delay(5);
byte EEPROM_ReadByte(int dev, unsigned int eeaddress)
byte rdata = 0xFF;
Wire.requestFrom(dev,1);
if (Wire.available()) rdata = Wire.read();
return rdata;
void store_data()
Serial.print("Write to 24C32N");
byte data=0;
for (unsigned int i = 0; i < 64; i++)
EEPROM_WriteByte(eeprom_address, i, data);
data++;
Serial.println("Done.");
void restore_data()
int val = 0;
byte data=0;
Serial.println("Read 24C32N: ");
data=EEPROM_ReadByte(eeprom_address, i);
Serial.print(data);
Serial.print(" ");
val++;
if (val >= 8) {
val = 0; //Для удобства, в строчку по 8 байт
Serial.println();
void clockDisplay()
String currentDate = String(day()) + "." + month() + "." + year();
Serial.println(currentTime);
Blynk.virtualWrite(V0, currentTime);
Blynk.virtualWrite(V1, currentDate);
unsigned int moist_sen_level()
unsigned int val;
val = analogRead(0);
Serial.print("ADC val="); Serial.println(val);
val = (val * 100) / 1023;
Serial.print("moist val(%)="); Serial.println(val);
return (val);
void MyWiFi()
int mytimeout = millis() / 1000;
ssid = wifi.getSSID();
pass = wifi.getPassword();
Serial.print("WiFi param. are: ");
Serial.print(ssid); Serial.print("__"); Serial.println(pass);
WiFi.begin(ssid.c_str(), pass.c_str());
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
if ((millis() / 1000) > mytimeout + 4)
{ // try for less than 4 seconds to connect to WiFi router
break;
if (WiFi.status() == WL_CONNECTED)
Serial.print("\nIP address: ");
Serial.println("\nCheck Router ");
Blynk.config(auth);
break;
void CheckConnection()
if (!Blynk.connected())
Serial.println("Not connected to Blynk server");
MyWiFi();
isFirstConnect = 1;
isSyncHrtcProvider = 0;
Serial.println("Still connected to Blynk server");
int i2cscan() {
//scanning i2c
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address < 16)
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
nDevices++;
else if (error == 4)
Serial.print("Unknow error at address 0x");
if (address < 16)
Serial.print("0");
Serial.println(address, HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
void syncRTC()
if (Blynk.connect())
Hrtc.adjust(DateTime(year(), month(), day(), hour(), minute(), second()));
void HrtcRead()
now_ = Hrtc.now();
Serial.print(now_.hour(), DEC);
Serial.print('-');
Serial.print(now_.minute(), DEC);
Serial.print('-');
Serial.print(now_.second(), DEC);
Serial.println();
void main_function()
if (!write_eeprom_done)
long Tbeg_write_eeprom=millis();
store_data();
write_eeprom_done=1;
Serial.print("T write in EEPROM = ");
Serial.println(millis() - Tbeg_write_eeprom);
if (!read_eeprom_done)
long Tbeg_read_eeprom=millis();
restore_data();
read_eeprom_done=1;
Serial.print("T read EEPROM = ");
Serial.println(millis() - Tbeg_read_eeprom);
cur_moisture = moist_sen_level();
Blynk.virtualWrite(V2, cur_moisture);
rssi = WiFi.RSSI();
Serial.print("RSSI="); Serial.println(rssi);
if (!scan_done)
i2cscan();
scan_done = true;
if (Blynk.connected())
wifi.setTimeout(180);
if (!wifi.autoConnect("AutoConnectAP"))
Serial.println("failed to connect and hit timeout");
delay(3000);
Serial.println("connected");
Blynk.config(auth); //Blynk.config(auth,WiFi.localIP());
Serial.print("ssid="); Serial.println(ssid.c_str());
Serial.print("pass="); Serial.println(pass.c_str());
if (Blynk.connect() == false)
delay(4000);
if (Blynk.connect() == true)
isFirstConnect = 1;
Serial.print("Blynk.connect() = "); Serial.println(Blynk.connect());
Wire.begin(sda, scl);
setSyncInterval(1);
rtc.begin();
timer.setInterval(20000L, syncRTC);
timer.setInterval(10000L, HrtcRead);
timer.setInterval(10000L, clockDisplay);
timer.setInterval(1000L, main_function);
timer.setInterval(20000L, CheckConnection);
Serial.println("done setup");
Here what I got:
Done.
T write in EEPROM = 329
Read 24C32N:
255 255 255 255 255 255 255 255
T read EEPROM = 18
ADC val=1
moist val(%)=0
RSSI=-82
ADC val=1
moist val(%)=0
RSSI=-82
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=2
moist val(%)=0
RSSI=-81
ADC val=0
moist val(%)=0
RSSI=-81
ADC val=0
moist val(%)=0
RSSI=-81
ADC val=4
moist val(%)=0
RSSI=-81
0-0-0
15:11:40
ADC val=0
moist val(%)=0
RSSI=-86
ADC val=0
moist val(%)=0
RSSI=-83
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=1
moist val(%)=0
RSSI=-81
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=2
moist val(%)=0
RSSI=-83
ADC val=0
moist val(%)=0
RSSI=-83
ADC val=0
moist val(%)=0
RSSI=-82
ADC val=0
moist val(%)=0
RSSI=-81
ADC val=0
moist val(%)=0
RSSI=-82
0-0-0
15:11:49
In output of serial monitor can be see:
0-0-0 this is the time from ds3231
15:11:40 this is the time of Blynk RTC widget.
What I should to change for avoid such behaviour of program?
Thank You.
