Hi all,
I find this project very interesting !
I’ve successful created a local Blynk server on Windows 10 so I try to do the same on my Raspberry PI 3.
Unfortunately, that don’t work.
I’ve followed the described procedure, the server runs but when I try to connect (as new user or to the admin page), the server crash immediately.
State of place :
- Raspberry PI 3 with Raspbian
- Oracle Java SDK : 8.0_73_B02
- Blynk server : server-0.14.0.jar (from github)
- OpenSSH_6.7p1 Raspbian-5+deb8u1, OpenSSL 1.0.1k 8 Jan 2015
I’ve tried with or without self generated ssl certificates : same problem
I’ve tried on a freshly Ubuntu (Mate) installation : same problem
Message from the console :
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x768f0494, pid=3438, tid=1712714848
JRE version: Java™ SE Runtime Environment (8.0_73-b02) (build 1.8.0_73-b02)
Java VM: Java HotSpot™ Client VM (25.73-b02 mixed mode linux-arm )
Problematic frame:
V [libjvm.so+0x4e1494] Unsafe_GetNativeByte+0x70
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try “ulimit -c unlimited” before starting Java again
An error report file with more information is saved as:
/home/pi/java/jre/bin/hs_err_pid3438.log
If you would like to submit a bug report, please visit:
http://bugreport.java.com/bugreport/crash.jsp
Aborted
extract of process log :
Stack: [0x66110000,0x66160000], sp=0x6615e338, free space=312k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.misc.Unsafe.getByte(J)B+0
j io.netty.util.internal.PlatformDependent0.getByte(J)B+4
j io.netty.util.internal.PlatformDependent.getByte(J)B+1
j io.netty.buffer.UnsafeByteBufUtil.getShort([BI)S+29
j io.netty.buffer.UnpooledUnsafeHeapByteBuf._getShort(I)S+5
j io.netty.buffer.UnpooledUnsafeHeapByteBuf.getShort(I)S+8
j io.netty.buffer.AbstractByteBuf.getUnsignedShort(I)I+2
j io.netty.handler.ssl.SslHandler.getEncryptedPacketLength(Lio/netty/buffer/ByteBuf;I)I+66
j io.netty.handler.ssl.SslHandler.decode(Lio/netty/channel/ChannelHandlerContext;Lio/netty/buffer/ByteBuf;Ljava/util/List;)V+89
j io.netty.handler.codec.ByteToMessageDecoder.callDecode(Lio/netty/channel/ChannelHandlerContext;Lio/netty/buffer/ByteBuf;Ljava/util/List;)V+46
j io.netty.handler.codec.ByteToMessageDecoder.channelRead(Lio/netty/channel/ChannelHandlerContext;Ljava/lang/Object;)V+81
j io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(Ljava/lang/Object;)V+9
j io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(Ljava/lang/Object;)Lio/netty/channel/ChannelHandlerContext;+35
j io.netty.handler.codec.ByteToMessageDecoder.handlerRemoved(Lio/netty/channel/ChannelHandlerContext;)V+29
j io.netty.channel.DefaultChannelPipeline.callHandlerRemoved0(Lio/netty/channel/AbstractChannelHandlerContext;)V+5
j io.netty.channel.DefaultChannelPipeline.callHandlerRemoved(Lio/netty/channel/AbstractChannelHandlerContext;)V+45
j io.netty.channel.DefaultChannelPipeline.replace0(Lio/netty/channel/AbstractChannelHandlerContext;Ljava/lang/String;Lio/netty/channel/AbstractChannelHandlerContext;)V+94
j io.netty.channel.DefaultChannelPipeline.replace(Lio/netty/channel/AbstractChannelHandlerContext;Ljava/lang/String;Lio/netty/channel/ChannelHandler;)Lio/netty/channel/ChannelHandler;+102
j io.netty.channel.DefaultChannelPipeline.replace(Lio/netty/channel/ChannelHandler;Ljava/lang/String;Lio/netty/channel/ChannelHandler;)Lio/netty/channel/ChannelPipeline;+8
j io.netty.handler.ssl.SniHandler.decode(Lio/netty/channel/ChannelHandlerContext;Lio/netty/buffer/ByteBuf;Ljava/util/List;)V+100
j io.netty.channel.DefaultChannelPipeline.fireChannelRead(Ljava/lang/Object;)Lio/netty/channel/ChannelPipeline;+5
j io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read()V+175
j io.netty.channel.nio.NioEventLoop.processSelectedKey(Ljava/nio/channels/SelectionKey;Lio/netty/channel/nio/AbstractNioChannel;)V+42
j io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized([Ljava/nio/channels/SelectionKey;)V+37
j io.netty.channel.nio.NioEventLoop.processSelectedKeys()V+15
j io.netty.channel.nio.NioEventLoop.run()V+84
j io.netty.util.concurrent.SingleThreadEventExecutor$2.run()V+13
j io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run()V+4
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
Seems there is a problem with SSL.
Hope you can help me.
Thanks in advance.
