i’ve a project running; Arduino Uno 4 buttons with Blynk and a relais-board. Connected with USB.
Did not work in one try, but with some help…
Next project: A stand-alone Adafruit HUZZAH ESP8266 (with the same relais-board)
Programming as ‘stand-alone esp’ Program uploaded like a charme… Hurray!
But: ‘device offline’
In Serial i got an “Invalid auth token” .
I checked, asked a new one, tried again… "Invalid auth token’
Now in Serial monitor i see it’s not conneting with server because of this but also: it runs to MAIN SERVER (at Blynk.cc BUT: i’m on a ‘European’ (?) server as per Dmitry’s instructions.
Where can i change the server-path and how (newbie answer, plz)
Thx Costas, your answer, and especcially the suggestion directing me to the possible fix, made me understand the whole.
It was a mix- up with libraries.
I have put all of the folders arduino, blynk and ( don’t forget !!) the arduino15* folder in a _OLD Arduino an re-installed.
Manually i made a change in de script ‘blynk-ser.bat’ (needed with Arduino Uno on serial USB) to direct all traffic to the rigth server ( in my case 45.55.96.146 instead of blynk cloudserver)
I had to after-install the esp866 library from the esp8266 comunity (found and installed with boardmanager) to connect my Adafruit HUZZAH esp8286 breakout board ( like!) and in the Sketch i had to put in the right server on the right place.
This last change i took from an an examplesketch in the ‘getting started’ info within Blynk.
Anyway: Thankx for pointing me to the right direction…
*Beware of this 'arduino15’folder.
It is in (Windows) path: username/AppData/Local/arduino15 Don’t forget to (re)move this as well !!
