Cemtes
February 10, 2021, 4:57am
1
Node red gives a websocket error when trying to connect to blynk after updating the local blynk server.
I use the node red pallet node-red-contrib-blynk-ws (v1.0.4) with my blynk app on a local server running on a raspberry pi. Everything has been working fine for about a year until I updated the server from version 0.41.13 to 0.41.15. Since the update, node red can’t connect to blynk, I initially get the error Websocket Error: WebSocket was closed before the connection was established followed by the error Websocket Error: socket hang up every 5 seconds as node red attempts to reconnect. I tested node red with a test project in the blynk cloud and it works fine so it seems the error is only with the local server. I have tried with and without SSL enabled on the blynk server (and made the appropriate changes to the address in node red) and get the same error.
The only thing that’s changed in my setup is the server version so I’m fairly certain it’s not a network error or connection error somewhere else in the system.
Does anyone have any suggestions on correcting this issue?
I had a similar issue a couple of weeks ago, when I upgraded my local server from 0.41.13 to 0.41.15.
I have to say that I tried quite a lot of different things, before I overcame the issue, and I can’t remember exactly what I did and in what sequence. I do recall that, due to a discussion about the Asia server being down and websockets not working after the main issue was fixed, I changed from ws://my_local_server_IP:8080/websockets to ws://my_local_server_IP:8080/websocket (without the ‘s’ on the end) and that is what I’m successfully running now.
I think a restart of Node-Red was needed, and I did experiment with deleting and re-creating my connection setting, but I don’t think that was needed in the end.
Cemtes
February 10, 2021, 11:04am
3
Amazing, thank you! I spent all day doing online searches and experimenting and couldn’t figure out what was wrong.
So just dropping the ‘s’ fixed it?
@gab.lau you might want to take a look at this, and change the URL info in the Node-Red ws contrib to reflect this?
Yes, a restart of NR was required in order for the WS library to make the change of the URL work…a simple config change in the node(s) and re-deploy would not do it.
I raised an issue regarding that aspect of the problem in the github repo, here: https://github.com/gablau/node-red-contrib-blynk-ws/issues/29
Cemtes
February 17, 2021, 3:31am
7
Yeah, that’s all it took. Dropped the “s” and it’s working great!
877
February 21, 2021, 5:20pm
8
Same issue here this week using node red / cloud server. Fixed it seems by dropping the ‘s’.
877
February 26, 2021, 7:36pm
9
Problem reared its head again today for me, I dropped the ‘s’ on all servers, restarted node red, nothing helps…
…revert blynkk the server to v0.41.14
February 26, 2021, 7:57pm
11
Yup I was thinking that, makes sense…
Trouble is, I’m using the Cloud server
The majority of my Home Automation systems still use the Blynk cloud servers and Node-Red running on two separate servers in two different countries (but both using the Frankfurt server) and I’m not experiencing any issues.
As it happens, both of these servers have their Blynk connections set-up to use websockets with an ‘s’ on the end, it’s just my local server where I have to use websocket
February 28, 2021, 9:37am
13
Hmm strange, I am having no end of trouble with my two cloud server connections not connecting…
Tried wss, ws and combinations of the two…
Can you post the condole output that you see when you type node-red-start (after doing a node-red-stop first of course)?
February 28, 2021, 10:39am
15
Here’s the log, I’m using wss connection on both cloud servers (my local server is disabled)
Cloud servers never connect…
Tests:
I switched one of the cloud servers to ws connection, both connect after re-deploy 20-30 seconds later.
Then I switch the other to ws and redeploy, connects instantly.
Now changes both servers to wss, redeploy connects instantly.
Seemingly totally random what works…
> node-red-docker@1.2.6 start /usr/src/node-red
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
28 Feb 10:32:00 - [info]
Welcome to Node-RED
28 Feb 10:32:00 - [info] Node-RED version: v1.2.6
28 Feb 10:32:00 - [info] Node.js version: v10.23.0
28 Feb 10:32:00 - [info] Linux 5.4.79-v7l+ arm LE
28 Feb 10:32:00 - [info] Loading palette nodes
28 Feb 10:32:01 - [debug] Module: node-red-contrib-threshold 0.0.3
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-threshold
28 Feb 10:32:01 - [debug] Module: node-red-contrib-alexa-cakebaked 4.0.2
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-alexa-cakebaked
28 Feb 10:32:01 - [debug] Module: node-red-contrib-bigtimer 2.7.3
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-bigtimer
28 Feb 10:32:01 - [debug] Module: node-red-contrib-blynk-ws 1.0.4
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-blynk-ws
28 Feb 10:32:01 - [debug] Module: node-red-contrib-bool-gate 1.0.2
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-bool-gate
28 Feb 10:32:01 - [debug] Module: node-red-contrib-contextbrowser 0.0.4
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-contextbrowser
28 Feb 10:32:01 - [debug] Module: node-red-contrib-diode 1.0.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-diode
28 Feb 10:32:01 - [debug] Module: node-red-contrib-homekit-bridged 1.2.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-homekit-bridged
28 Feb 10:32:01 - [debug] Module: node-red-contrib-huemagic 3.0.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-huemagic
28 Feb 10:32:01 - [debug] Module: node-red-contrib-ibm-watson-iot 0.2.8
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-ibm-watson-iot
28 Feb 10:32:01 - [debug] Module: node-red-contrib-influxdb 0.5.4
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-influxdb
28 Feb 10:32:01 - [debug] Module: node-red-contrib-interval-length 0.0.4
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-interval-length
28 Feb 10:32:01 - [debug] Module: node-red-contrib-moment 4.0.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-moment
28 Feb 10:32:01 - [debug] Module: node-red-contrib-play-audio 2.5.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-play-audio
28 Feb 10:32:01 - [debug] Module: node-red-contrib-ramp-thermostat 0.8.3
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-ramp-thermostat
28 Feb 10:32:01 - [debug] Module: node-red-contrib-simple-gate 0.4.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-simple-gate
28 Feb 10:32:01 - [debug] Module: node-red-contrib-sonoff-tasmota 3.0.0
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-sonoff-tasmota
28 Feb 10:32:01 - [debug] Module: node-red-contrib-alexa-home-skill 0.1.19
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-alexa-home-skill
28 Feb 10:32:01 - [debug] Module: node-red-contrib-timeout 1.1.4
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-timeout
28 Feb 10:32:01 - [debug] Module: node-red-contrib-tplink-smarthome 0.1.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-tplink-smarthome
28 Feb 10:32:01 - [debug] Module: node-red-contrib-unifi 0.1.16
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-unifi
28 Feb 10:32:01 - [debug] Module: node-red-contrib-zigbee2mqtt 0.6.3
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-contrib-zigbee2mqtt
28 Feb 10:32:01 - [debug] Module: node-red-dashboard 2.28.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-dashboard
28 Feb 10:32:01 - [debug] Module: node-red-node-email 1.8.3
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-email
28 Feb 10:32:01 - [debug] Module: node-red-node-ledborg 0.0.22
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-ledborg
28 Feb 10:32:01 - [debug] Module: node-red-node-ping 0.2.2
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-ping
28 Feb 10:32:01 - [debug] Module: node-red-node-random 0.3.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-random
28 Feb 10:32:01 - [debug] Module: node-red-node-rbe 0.2.9
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-rbe
28 Feb 10:32:01 - [debug] Module: node-red-node-sentiment 0.1.6
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-sentiment
28 Feb 10:32:01 - [debug] Module: node-red-node-serialport 0.11.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-serialport
28 Feb 10:32:01 - [debug] Module: node-red-node-smooth 0.1.2
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-smooth
28 Feb 10:32:01 - [debug] Module: node-red-node-tail 0.1.1
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-tail
28 Feb 10:32:01 - [debug] Module: node-red-node-twitter 1.1.7
28 Feb 10:32:01 - [debug] /data/node_modules/node-red-node-twitter
28 Feb 10:32:01 - [debug] Module: node-red-node-rbe 0.2.9 *ignored due to local copy*
28 Feb 10:32:01 - [debug] /usr/src/node-red/node_modules/node-red-node-rbe
28 Feb 10:32:01 - [debug] Module: node-red-node-tail 0.1.1 *ignored due to local copy*
28 Feb 10:32:01 - [debug] /usr/src/node-red/node_modules/node-red-node-tail
28 Feb 10:32:03 - [warn] ledborg : rpi-gpio.errors.libnotfound
28 Feb 10:32:05 - [info] Dashboard version 2.28.1 started at /ui
28 Feb 10:32:05 - [info] Settings file : /data/settings.js
28 Feb 10:32:05 - [info] Context store : 'default' [module=localfilesystem]
28 Feb 10:32:05 - [info] User directory : /data
28 Feb 10:32:05 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Feb 10:32:05 - [info] Flows file : /data/flows.json
28 Feb 10:32:05 - [info] Server now running at http://127.0.0.1:1880/
28 Feb 10:32:06 - [debug] loaded flow revision: 9662f60b08c22de3693974bf909b16bd
28 Feb 10:32:06 - [debug] red/runtime/nodes/credentials.load : no user key present
28 Feb 10:32:06 - [debug] red/runtime/nodes/credentials.load : using default key
28 Feb 10:32:06 - [debug] red/runtime/nodes/credentials.load : keyType=system
28 Feb 10:32:06 - [warn]
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
28 Feb 10:32:06 - [info] Starting flows
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : global
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : bd52b987.d668e8
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : cc9bb259.6c984
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : be5275e8.e06c78
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 6043bdc.7576744
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : b08efd68.4f78
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : 5a9d8292.529c2c
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : cce3159f.ed5978
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : fa1345d7.0957a8
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 564b0ab8.42d084
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 2a6827d4.9b5e18
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : c351e9b7.248858
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 28b5cbf9.f29374
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : d176a11a.5c791
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : e3ce390a.5c1998
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : e82860b0.465cf
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : a6ac6110.78c0c
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : ab2be502.455278
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 738a4866.c25308
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 2776ae8.d8d2052
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : b1f887fe.970e58
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 22e4edf9.4432f2
28 Feb 10:32:06 - [debug] red/nodes/flows.start : starting flow : 73ce8bea.e89a44
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : 3c0508ca.d53c08
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : d64196b0.273b98
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : 390c5881.bc3b98
28 Feb 10:32:06 - [debug] red/nodes/flows.start : not starting disabled flow : e5f48c9e.09468
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] LOG PINS []
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://blynk-cloud.com/websockets
28 Feb 10:32:06 - [info] [blynk-ws-client:Family Blynk account] LOG PINS []
28 Feb 10:32:06 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://blynk-cloud.com/websockets
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk TEST LOCAL] LOG PINS []
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register notify node
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 13
28 Feb 10:32:06 - [info] [blynk-ws-client:Family Blynk account] Register notify node
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 4
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 7
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register LCD node pin: 70
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 0
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 104
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: style-btn pin: 104
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: app
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 106
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 108
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: style-btn pin: 106
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: style-btn pin: 108
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 97
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 62
28 Feb 10:32:06 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 3
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 18
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 105
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 116
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 117
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register notify node
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 102
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: style-btn pin: 102
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: app
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 100
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: style-btn pin: 100
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 103
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 109
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 111
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 110
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 50
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 49
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 101
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 254
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 61
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 62
28 Feb 10:32:07 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Register input node - type: write pin: 63
28 Feb 10:32:07 - [info] [blynk-ws-client:Family Blynk account] Register notify node
28 Feb 10:32:07 - [info] Started flows
(node:18) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 error listeners added. Use emitter.setMaxListeners() to increase limit
(node:18) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 opened listeners added. Use emitter.setMaxListeners() to increase limit
(node:18) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 connected listeners added. Use emitter.setMaxListeners() to increase limit
(node:18) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 closed listeners added. Use emitter.setMaxListeners() to increase limit
(node:18) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 disabled listeners added. Use emitter.setMaxListeners() to increase limit
28 Feb 10:32:07 - [info] [zigbee2mqtt-server:5f73645c.dbf83c] MQTT Connected
28 Feb 10:32:07 - [info] [zigbee2mqtt-server:5f73645c.dbf83c] Refreshing devices
28 Feb 10:32:07 - [info] [mqtt-broker:5615eece.b3a81] Connected to broker: mqtt://192.168.1.95:1883
28 Feb 10:32:07 - [info] [alexa-remote-account:f24a22c6.8037c] intialising with the PROXY method and saved data...
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: starting initialisation:
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: Use as Login-Amazon-URL: amazon.co.uk
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: Use as Base-URL: alexa.amazon.co.uk
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: cookie was provided
28 Feb 10:32:07 - [debug] [alexa-remote-account:f24a22c6.8037c] Alexa-Remote: Sending Request with {"host":"alexa.amazon.co.uk","path":"/api/bootstrap?version=0","method":"GET","timeout":10000,"headers":{}}
28 Feb 10:32:07 - [error] [influxdb out:6cd8a4f8.f3b05c] Error: A 400 Bad Request error occurred: {"error":"unable to parse 'weather,topic=Xiaomi_8_weather_bathroom,make=aqara,location=bathroom,connection=zigbee,power=battery,friendlyname=Bathroom batteryPercent=100,batteryVolts=3005,humidity=62.68,linkQuality=undefined,pressure=1019.7,temperature=21.3': invalid boolean"}
28 Feb 10:32:07 - [info] [zigbee2mqtt-server:5f73645c.dbf83c] MQTT Subscribed to: "zigbee2mqtt/#
28 Feb 10:32:08 - [info] [blynk-ws-client:Blynk TEST LOCAL] Connection disabled by configuration
2
28 Feb 10:32:09 - [warn] [blynk-ws-client:Blynk (LIVE SYSTEM)] wss.//139.59.206.133.80/websockets
28 Feb 10:32:09 - [warn] [blynk-ws-client:Family Blynk account] wss.//139.59.206.133.80/websockets
28 Feb 10:32:19 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:19 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:19 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:19 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:24 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:24 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:24 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:24 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:24 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:24 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:24 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:24 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:24 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:24 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:29 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:29 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:29 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:29 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:29 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:29 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:29 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:29 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:29 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:29 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:34 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:34 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:34 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:34 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:34 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:34 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:34 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:34 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:34 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:34 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope ff528803.130fc8:bd52b987.d668e8
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope f3f010b6.7a196:fa1345d7.0957a8
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope a0728fd5.03674:fa1345d7.0957a8
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 65f2e755.2825e8:e82860b0.465cf
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 9358047e.6d38f8:ab2be502.455278
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 3245d3fe.9988dc:ab2be502.455278
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 66e90019.baf01:2776ae8.d8d2052
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 7287874a.557308:b1f887fe.970e58
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 457a996d.e31138:b1f887fe.970e58
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 2f77266f.98643a:22e4edf9.4432f2
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope global
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope 8fd574e.9baab88:e82860b0.465cf
28 Feb 10:32:36 - [debug] Flushing localfilesystem context scope cad949db.837468:e82860b0.465cf
28 Feb 10:32:39 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:39 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:39 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:39 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:39 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:39 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:39 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:39 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:39 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:39 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:44 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:44 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:44 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:44 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:44 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:44 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:44 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:44 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:44 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:44 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:49 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:49 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:49 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:49 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:49 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:49 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:49 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:49 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:49 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:49 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:54 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:54 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:54 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:54 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:54 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:54 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:54 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:54 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:54 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:54 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:59 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:59 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:32:59 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:59 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:32:59 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:32:59 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:32:59 - [error] [blynk-ws-client:Family Blynk account] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:32:59 - [info] [blynk-ws-client:Family Blynk account] Client Error
28 Feb 10:32:59 - [info] [blynk-ws-client:Family Blynk account] Reconnect in 5 seconds...
28 Feb 10:32:59 - [info] [blynk-ws-client:Family Blynk account] Websocket closed: wss://139.59.206.133:80/websockets
28 Feb 10:33:04 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:33:04 - [info] [blynk-ws-client:Family Blynk account] Start secure connection: wss://139.59.206.133:80/websockets
28 Feb 10:33:04 - [error] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket Error: Client network socket disconnected before secure TLS connection was established
28 Feb 10:33:04 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Client Error
28 Feb 10:33:04 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Reconnect in 5 seconds...
28 Feb 10:33:04 - [info] [blynk-ws-client:Blynk (LIVE SYSTEM)] Websocket closed: wss://139.59.206.133:80/websockets
877:
Have you noticed these error messages?
February 28, 2021, 12:58pm
17
Yes I have noticed them, a quick google gives mixed info. Some say it’s just a warning, ignore. Other says it’s one of the nodes causing the issue.
