Hi, Costas, many thanks for solving my last problem, i have shared everything on that issue and marked it as solved. Thinking more Generic, i am prepared to do the same with a NEC IR project, as before, this below code works but not with blynk, can you do your magic again and i will then share it for others to benefit, i must emphasis that i am trying hard to learn but i am a novice but willing to try and learn.
#include <IRremoteESP8266.h>
char auth[] = "********************************";
char ssid[] = "**********";
char pass[] = "**********";
char server[] = "************";
IRsend irsend(4); //an IR led is connected to GPIO pin 4 (D2)
irsend.begin();
irsend.sendNEC(0X2FDE817, 32); // 32 bits, no repeat
Blynk.begin(auth, ssid, pass, server);
thanks costas, will share all later, just for your info, unlike the samsung code the app PUSH only needed quick push, the NEC code app PUSH needed hold longer, any ideas why that might be?
You should mark this as solved and if you want you can open a new one with “made with blynk”.
Btw about your project, looks really cool ! Are you able to only turn your tv on and off or do you have the possibility of switching channels etc ?
Hi I am the original poster of this project, sorry but there is not a schematic available, it was not posted as a project it was posted for help with some code that I was stuck on , I soldered up a custom circuit board for the hardware side of things which was quite basic using and ESP8266 chip with a 5v to 3.3 v voltage regulator, A transistor and an infrared LED .
Hi, good evening, I’m behind a project so that I can delligate the TV through the space, will you have a basic material like this.
thank you for your attention
