I am running Blynk on Linux and connecting through putty and have set up same it works fine.I am using command java -jar server-0.38.2.jar -dataFolder ACTUAL_PATH & it will run and I can view the admin page but as soon as I close the session the webpage and server is unreachable ,kindly guide how to keep same running on exit from the session
FYI, this is a Linux question, not Blynk specific
But as you show, the & symbol at the end should allow the session to close but keep the script running.
Google for further info if this is not working in your case.
I got the resolution…thx for the guidance
