I’m attempting to setup Blynk for the first time using a Raspberry Pi 2 - Model B. I’m a complete novice at this stuff.
Here’s the error. I’ve hidden most of my auth token.
$ blynk.js 7da54…a7f2b
OnOff mode
Connecting to: blynk-cloud.com 8441
SSL authorization…
events.js:87
throw Error(‘Uncaught, unspecified “error” event.’);
Error: Uncaught, unspecified “error” event.
at Error (native)
at emit (events.js:87:13)
at Blynk.error (/usr/local/lib/node_modules/blynk-library/blynk.js:571:8)
at null. (/usr/local/lib/node_modules/blynk-library/blynk.js:534:48)
at emit (events.js:107:17)
at TLSSocket. (/usr/local/lib/node_modules/blynk-library/blynk-node.js:197:16)
at TLSSocket.emit (events.js:107:17)
at TLSSocket. (_tls_wrap.js:942:18)
at TLSSocket.emit (events.js:104:17)
at TLSSocket._finishInit (_tls_wrap.js:460:8)
It doesn’t appear to be a firewall issue or an issue connecting to the internet. I can telnet to the Blynk cloud server using:
$ telnet cloud.blynk.cc 8441
Trying 45.55.195.102…
Connected to cloud.blynk.cc.
I think I’m using current versions:
$ node -v
v0.12.6
$ npm -v
3.8.6
The SD Card is freshly formatted and a plain vanilla Raspbian was installed. After connecting to the Pi, I installed node.js according to these instructions: Installing node.js | Node.js Embedded Development on the Raspberry Pi | Adafruit Learning System
Then I ran:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install build-essential
sudo npm install -g npm
sudo npm install -g onoff
sudo npm install -g blynk-library
This simple “hello world” node.js runs.
$ node hello.js
Node is installed!
Any suggestions on what I could try next?
