[Solved] Blynk iOS App (2.8.0) stopped showing pins
After recent update (2.8.0) app stopped showing pins on my local server. Can’t figure out where is problem but only thing I’ve changed in last days was app update. Before that everything worked nicely.
I tried to make new server in different folder and create new account. After trying to make new project I’m getting error - cannot connect to server. Then app creates project but I’m unable to select pins once more.
Logs show that new account and dashboard is created.
Attached are screen shots with problem.
Screen shot with pins selection.
https://github.com/blynkkk/blynk-server#update-instruction-for-unix-like-systems
Server update should always go before app update. In order to update your server with new version you need to kill old process and start new one.
Thanks a lot! Problem solved.
