I’m trying to connect together ESP-01 and DHT22,
but after I’m uploading the code to ESP8266,
I’m always got the same repeated error after blynk was connected:
Failed to read from DHT sensor!
I’m tried to use external 3.3/5v for DHT22 but no luck.
I think the problem is in wrong PIN number for GPIO2 in my ESP-01 for DHT. Am I right?
Have no idea how to solve this problem. Please help!
Pinout:
Arduino IDE flashing params:
Code(all ext libraries is the same as links inside the code):
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "";
char pass[] = "YourPassword";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
Top power rail is 3.3v bottom power rail is 5v
