I have Arduino Uno R3 and Arduino Genuine WiFi Shield and I try Blynk example Arduino_WiFi, so there is what i got
[0] Connecting to wlElstudija…
[10001] My IP: 192.168.10.54
[10002] Blynk v0.3.1
[10002] Connecting to яloud.blynk.cc:8442
[19035] Connecting to яloud.blynk.cc:8442
[28039] Connecting to яloud.blynk.cc:8442
[37042] Connecting to яloud.blynk.cc:8442
[46046] Connecting to яloud.blynk.cc:8442
[55049] Connecting to яloud.blynk.cc:8442
[64053] Connecting to яloud.blynk.cc:8442
[73056] Connecting to яloud.blynk.cc:8442
[82060] Connecting to яloud.blynk.cc:8442
[91063] Connecting to яloud.blynk.cc:8442
[100067] Connecting to яloud.blynk.cc:8442
[109070] Connecting to яloud.blynk.cc:8442
[118074] Connecting to яloud.blynk.cc:8442
[127078] Connecting to яloud.blynk.cc:8442
And continue…
I am too think that it was strange that in cloud “C” letter place is that я
I have nothing change in the code. I have paste clean just now downloaded new library.
After that I was try to replace in example code
this
with this
Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 8442);
but result what I see in Serial monitor is the same!
Ok, I have check the same example on another computer and there all is right with letter, but still can’t connect.
[0] Connecting to wlElstudija3…
[10001] My IP: 192.168.0.100
[10003] Connecting to cloud.blynk.cc:8442
[21033] Connecting to cloud.blynk.cc:8442
[31037] Connecting to cloud.blynk.cc:8442
[41040] Connecting to cloud.blynk.cc:8442
[51043] Connecting to cloud.blynk.cc:8442
[61044] Connecting to cloud.blynk.cc:8442
[71047] Connecting to cloud.blynk.cc:8442
[81049] Connecting to cloud.blynk.cc:8442
[91052] Connecting to cloud.blynk.cc:8442
[101054] Connecting to cloud.blynk.cc:8442
[111056] Connecting to cloud.blynk.cc:8442
[121059] Connecting to cloud.blynk.cc:8442
[131060] Connecting to cloud.blynk.cc:8442
[141063] Connecting to cloud.blynk.cc:8442
[151065] Connecting to cloud.blynk.cc:8442
It is connect to router, but when I try WiFiWebClient example, seems it was not connecting don’t know why. I also try vymanskyy suggestion, i can connect thru PC telnet to cloud.blynk.cc
I am very tired by searching at least one working WiFi solution for Arduino to run Blynk. I am spend about 2 weeks on this and I have no luck. At first I was trying ESP8266 as shield for arduino. No luck, no one can help with it. Second I read that one WiFi solution with which is no problems is Arduino Genuine WiFi Shield, I was buy it for big money and there it is - Doesn’t works! Next I have already buy C3000 (now waiting for it comes, last hope). Only one time I have be connected to blynk, and it was with wired Ethernet shield. But I need WiFi!!! Can some one help me with run Blynk on WiFi? May be some stable solution to go WiFi with arduino?
Why WiFiWebClient doesn’t works, I am realy don’t know. I found 1 year old post in Arduino forums, with similar trouble, but there I wasn’t find solution. I always think that genuine Shields need to work perfect as expected.
I was try with two diferent routers, and on booth Ethernet shield (with RJ45 wire) works perfect. But WiFi shield doesn’t connect to cloud.blynk.cc
Step-by-step
I have genuine Arduino Uno R3 with genuine WiFi Shield on it. I load in Arduino basis Blynk Arduino_WiFi example (with just changet token, ssid, pass) and it does’t works.
When I connect with Arduino Uno R3 and with Arduino Ethernet Shield on it and load basic blynk example Arduino_Ethernet, so it is only one shield which works for me.
I have the latest Arduino software, the latest WiFi shield firmware and the latest Blynk library and I encounter the same issue as you. When connecting to the server, instead of saying connecting to could.blynk.cc the Serial reports it is trying to connect to ?loud.blynk.cc which of course will not work.
I managed to work around the issue with two steps. Under WiFi credentials add 1 line.
// Your WiFi credentials
char ssid[] = “YourNetworkName”;
char pass[] = “YourPassword”;
IPAddress ip (45,55,195,102);
Under void setup, comment the first line, uncomment the last and replace server_ip and port for ip and 8442.
Serial.begin(9600); //Blynk.begin(auth, ssid, pass);
// Or specify server using one of those commands: //Blynk.begin(auth, ssid, pass, “server.org”, 8442);
Blynk.begin(auth, ssid, pass, ip, 8442);
I’m using a UNO board.
a quick question about the Arduino ethernet shield you used originally, I don’t want to waste money on something that won’t work.
Does it need a POE module to connect like here? - https://store.arduino.cc/product/A000075
or is this one ok without POE module to get connected online?
POE means “Power Over Ethernet” which means that the board can potentially be powered via the same network cable that will be used to communicate with it. But that only works if the cable is coming from a device that supplies that power, otherwise the POE module does nothing special and it is cheaper (and more compact) to buy a shield without a POE module. I used both in the past and both work really well.
Your link points to the exact WiFi module I have. It is now “really” old and obsolete but you can get the new one here: https://www.arduino.cc/en/Main/ArduinoWiFiShield101 if you want to get your Uno connected without a computer attached to it. Or you can buy the Arduino Yùn that has its own integrated Wifi module plus many other functionalities you can explore. https://www.arduino.cc/en/Main/ArduinoBoardYun
