It either moves him to Nigeria, or it starts his GPS… either way it should place the two together at last
I’m do it and serial monitor: and in blynk again show nigeria
yesterday I used blow sket with my NodeMCU and UBLOX 7 GPS module and its worked perfectly
https://github.com/mkconer/ESP8266_GPS/blob/master/ESP8266_GPS_OLED_Youtube.ino
@Gunner earlier I was going to suggest that @ErfanDL moves to Nigeria and all his (GPS) problems would be solved
Please do not mock me
Relax @ErfanDL You have asked for help and you are getting help… Us regulars tend to joke a bit, but we’re not mocking you, just some levity about common (if not practical ;)) GPS solution ideas.
Forget Nigeria, forget the map, forget Blynk. The first thing you need from this sketch and almost every sketch you will create for the next 12 months is get accurate data from Serial Monitor.
What does SM show for this sketch:
// GPS.ino https://community.blynk.cc/t/arduino-or-nodemcu-gps-tracking-system-on-map-widget/15739/33
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 12, TXPin = 13;
static const uint32_t GPSBaud = 9600;
unsigned int move_index;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
char auth[] = "4bb191e6da5a438bb071ecca688732f3";
char ssid[] = "MikroTik Home";
char pass[] = "";
char server[] = "192.168.1.104";
WidgetMap myMap(V5);
Serial.begin(115200); // Debug console
Serial.println();
ss.begin(GPSBaud);
Blynk.begin(auth, ssid, pass, server);
timer.setInterval(5000L, getCoordinates); // 5s not 1s intervals
void getCoordinates()
Blynk.virtualWrite(V6, millis() / 1000);
move_index++;
//float latitude = (gps.location.lat(), 6);
//float longitude = (gps.location.lng(), 6);
//Serial.println(latitude, 6);
//Serial.println(longitude, 6);
//Blynk.virtualWrite(V7, latitude);
//Blynk.virtualWrite(V8, longitude);
//myMap.location(move_index, latitude, longitude, "Iran");
Serial.print("LAT: ");
Serial.println(gps.location.lat(), 6);
Serial.print("LONG: ");
Serial.println(gps.location.lng(), 6);
thanks. Please do not hesitate to help me out
No problem… my best advice… listen to @Costas!! He is smart, but like me, prone to back away if his directions go unheeded.
SM for this sketch (you might need to set GPSBaud at 9600):
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 12(rx) and 13(tx).
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
ss.begin(GPSBaud);
Serial.println(F("DeviceExample.ino"));
Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
Serial.println();
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
Serial.println();
gps location from serial monitor worked
Progress at last.
I only have GPS with my Smartphones but give me some time and I will Blynkify your working sketch.
thank you so much. I’m waiting
Are you using 4800 or 9600 for the GPS baud?
9600
Look through all the comments in this sketch and see how you go with it.
/* BlynkifyGPS.ino for https://community.blynk.cc/t/arduino-or-nodemcu-gps-tracking-system-on-map-widget/15739
Sketch for physical GPS device connected to a decent ESP
In map widget set SHOW MY LOCATION to NO unless you also want Smartphone actual location in addition to GPS device + ESP
static const int RXPin = 4, TXPin = 3;
TinyGPSPlus gps; // The TinyGPS++ object
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
char pass[] = "";
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
bool simulation = false; // set to true for simulation mode, else false. If IranHack is true this must be false
// simulation location is in Egypt
bool IranHack = false; // set to true if GPS is faulty, else false. If simulation is true this must be false
Serial.println();
ss.begin(GPSBaud);
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Blynk.virtualWrite(V10, "GPS ERROR"); // Value Display widget set as PUSH frequency on V10
Blynk.virtualWrite(V7, "--------"); // Value Display widget set as PUSH frequency on V7 LATITUDE
Blynk.virtualWrite(V8, "--------"); // Value Display widget set as PUSH frequency on V8 LONGITUDE
delay(1000); // NOT RECOMENDED
if(simulation == true || IranHack == true)
displayInfo();
while (ss.available() > 0) // sketch displays information every time a new sentence is correctly encoded.
displayInfo();
void displayInfo()
if (gps.location.isValid() || simulation == true || IranHack == true)
//move_index++; // moving index, maybe use later
Blynk.virtualWrite(V10, "GPS OK");
float latitude = (gps.location.lat()); // removed , 6 as it can't be used for creating the float
float longitude = (gps.location.lng()); // removed , 6 as it can't be used for creating the float
if(latitude == 0 && longitude == 0 ) // checking to see if the 2 floats variables are correct
Blynk.virtualWrite(V10, "0,0");
if(simulation == true) // location in Egypt
latitude = 30.000123; // also used for debugging
longitude = 30.000987; // also used for debugging
if(IranHack == true)
latitude = 32.644824;
longitude = 51.681746;
Serial.println(latitude, 6); // float to x decimal places
Blynk.virtualWrite(V7, String(latitude, 6));
Blynk.virtualWrite(V8, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "GPS_Location");
Blynk.virtualWrite(V10, "GPS INVALID");
Serial.println();
@Costas @Gunner
thanks a lot. the problem is solved I will never forget this great favor
update: the NodeMCU disconnecting from AP and cant keep connection
That will be because the main loop() is not really suitable for Blynk.
I just wanted to ensure your GPS and the Map widget were working OK.
Now you know the basic system works the fine tuning can begin.
thanks. which line is need tuning ?
@ErfanDL this area in loop() is what needs to be fine tuned but it’s a little difficult for me without a GPS device, hence some of the simulation code in the sketch:
displayInfo();
displayInfo();
