ok thank you
now i changed by AT commad from 9600 to 19200 baund
after i used this
//#define BLYNK_DEBUG // debug
#include <ESP8266_Lib.h>
char auth[] = "d8985243b75b462b8xxxxx31ec5c3c1";
char ssid[] = "TP-LINK_Outdoor_871430";
//char ssid[] = "Vodafone-33734410";
//char ssid[] = "ubnt";
char pass[] = "wifidifaxxxxxterrebecca";
//char ssid[] = "VodafoneMobileWiFi-599C69";
//char pass[] = "LE7HL07244";
int enablezona1 ;
#define EspSerial Serial1
#define ESP8266_BAUD 19200
ESP8266 wifi(&EspSerial);
int pinSettore1 = 41; //cancelllo
Serial.begin(19200);
Serial.println("<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<inizio setup");
delay(30);
pinMode( pinSettore1, OUTPUT );
digitalWrite( pinSettore1, HIGH );
BLYNK_WRITE(V1)// input : accende zona 1
{ BLYNK_LOG("zona1 Got a value: % i", param.asInt());
enablezona1 = param.asInt();
if (enablezona1 == 1)
{ digitalWrite(pinSettore1, LOW); //accendo il relay
} else
{ digitalWrite(pinSettore1, HIGH); //spengo il relay
{ Blynk.run();
the result is Always one CRASH!
[7766] zona1 Got a value: 1
[11698] ⸮<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<inizio setup
[73]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.7 on Arduino Mega
[619] Connecting to TP-LINK_Outdoor_871430
[3703] AT version:0.22.0.0(Mar 20 2015 10:04:26)
SDK version:1.0.0
compile time:Mar 20 2015 11:00:32
[4734] Failed to enable MUX
[9848] +CIFSR:STAIP,"192.168.1.13"
+CIFSR:STAMAC,"60:01:94:0f:8f:e6"
[9852] Connected to WiFi
[10219] Ready (ping: 59ms).
[22861] zona1 Got a value: 1
[30632] <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<inizio setup
[73]
___ __ __
SDK version:1.0.0
[9849] +CIFSR:STAIP,"192.168.1.13"
[9853] Connected to WiFi
[10211] Ready (ping: 60ms).
- i tested every 30 seconds but crash every time
an others thing : i tested also without BLYNK , i belived that this no crashed but… after 3 hours has crashed again!
this is the sketch without Blynk , managed by RTC:
// versione senza Blynk
#include <Wire.h>
#include <RTClib.h>
int mattina=0;
int sera=1;
int pranzo=1;
int zona;
//-----rtc
// 43 rele 1 siepe
// 41 cancello
//39 rele 3 nord sinistra
//37 rele 4 fronte
//35 patio 5
//33 nord destro rel 7
// 31 nord centro rel 6
//29 piscina piccola rel8
//27 tubo piscina rel 9
//25 rele vuoto
//23 vuoto
short pinSettore1 = 41; //cancelllo
short pinSettore2 = 27; //tubo piscina
short pinSettore3 = 43 ;//siepe
short pinSettore4 = 29; //piscina piccola
short pinSettore5 = 37 ; //fronte
short pinSettore6 = 35 ; //patio
short pinSettore7 = 31; //nord centro
short pinSettore8 = 39;//nord sin
short pinSettore9 = 33;//nord dest
short pinSettore10 = 25; // servizi tubo 25
short pinSettore11 = 23; //libero
short pinSettore12 = 23; //libero
short pinSettore13 = 23; //libero
short pinSettore14 = 23; //libero
short pinSettore15 = 23; //libero
short pinSettore16 = 23; //libero
RTC_DS1307 RTC;
// Set console baud rate
//----rtc
Wire.begin();
RTC.begin();
//dichiarazione pin che danno 0/1 ai relay devono essere output perchè se no non accendo i rele
pinMode( pinSettore1, OUTPUT ); //pin2
pinMode( pinSettore2, OUTPUT );
pinMode( pinSettore3, OUTPUT );
pinMode( pinSettore4, OUTPUT );
pinMode( pinSettore5, OUTPUT );
pinMode( pinSettore6, OUTPUT );
pinMode( pinSettore7, OUTPUT );
pinMode( pinSettore8, OUTPUT );
pinMode( pinSettore9, OUTPUT );
pinMode( pinSettore10, OUTPUT );
pinMode( pinSettore11, OUTPUT );
pinMode( pinSettore12, OUTPUT );
pinMode( pinSettore13, OUTPUT );
pinMode( pinSettore14, OUTPUT );
pinMode( pinSettore15, OUTPUT );
pinMode( pinSettore16, OUTPUT );
all_off();
//----- da commentare
//RTC.sqw(1); //0 Led off - 1 Freq 1Hz - 2 Freq 4096kHz - 3 Freq 8192kHz - 4 Freq 32768kHz
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
//RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
// RTC.adjust(DateTime(__DATE__, __TIME__));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
//RTC.adjust(DateTime(2017, 6, 7, 12, 19, 0));
//-- da commentare al secondo avvio
RTC.adjust(DateTime(2017, 6, 7, 20, 59, 53));
adesso();
delay(3000);
//----rtc
}//fine setup
void all_off () {
//HIGH mette tutti OFF è spento
digitalWrite( pinSettore2, HIGH );
digitalWrite( pinSettore3, HIGH );
digitalWrite( pinSettore4, HIGH );
digitalWrite( pinSettore5, HIGH );
digitalWrite( pinSettore6, HIGH );
digitalWrite( pinSettore7, HIGH );
digitalWrite( pinSettore8, HIGH );
digitalWrite( pinSettore9, HIGH );
digitalWrite( pinSettore10, HIGH );
digitalWrite( pinSettore11, HIGH );
digitalWrite( pinSettore12, HIGH );
digitalWrite( pinSettore13, HIGH );
digitalWrite( pinSettore14, HIGH );
digitalWrite( pinSettore15, HIGH );
digitalWrite( pinSettore16, HIGH );
{ delay(1000);
adesso();
DateTime now = RTC.now();
int _hour = now.hour();
int _minute = now.minute();
int _secondi = now.second();
if (mattina == 1)
if (_hour == 06 && _minute == 00 && _secondi ==00) {accendi(pinSettore1); Serial.println("Start irrigazione");}
if (_hour == 06 && _minute == 10 && _secondi ==00) spegni(pinSettore1);
if (_hour == 06 && _minute == 10 && _secondi ==00) accendi(pinSettore2);
if (_hour == 06 && _minute == 20 && _secondi ==00) spegni(pinSettore2);
if (_hour == 06 && _minute == 20 && _secondi ==00) accendi(pinSettore4);
if (_hour == 06 && _minute == 30 && _secondi ==00) spegni(pinSettore4);
if (_hour == 06 && _minute == 30 && _secondi ==00) accendi(pinSettore5);
if (_hour == 06 && _minute == 40 && _secondi ==00) spegni(pinSettore5);
if (_hour == 06 && _minute == 40 && _secondi ==00) accendi(pinSettore6);
if (_hour == 06 && _minute == 50 && _secondi ==00) spegni(pinSettore6);
if (_hour == 06 && _minute == 50 && _secondi ==00) accendi(pinSettore7);
if (_hour == 07 && _minute == 00 && _secondi ==00) spegni(pinSettore7);
if (_hour == 07 && _minute == 00 && _secondi ==00) accendi(pinSettore8);
if (_hour == 07 && _minute == 10 && _secondi ==00) spegni(pinSettore8);
if (_hour == 07 && _minute == 10 && _secondi ==00) accendi(pinSettore9);
if (_hour == 07 && _minute == 20 && _secondi ==00) spegni(pinSettore9);
if (_hour == 07 && _minute == 20 && _secondi ==00) accendi(pinSettore10);
if (_hour == 07 && _minute == 30 && _secondi ==00) {spegni(pinSettore10) ; Serial.println("Stop irrigazione");}
if (pranzo == 1)
if (_hour == 13 && _minute == 00 && _secondi ==00) {accendi(pinSettore1); Serial.println("Start irrigazione");}
if (_hour == 13 && _minute == 10 && _secondi ==00) spegni(pinSettore1);
if (_hour == 13 && _minute == 10 && _secondi ==00) accendi(pinSettore2);
if (_hour == 13 && _minute == 20 && _secondi ==00) spegni(pinSettore2);
if (_hour == 13 && _minute == 20 && _secondi ==00) accendi(pinSettore4);
if (_hour == 13 && _minute == 30 && _secondi ==00) spegni(pinSettore4);
if (_hour == 13 && _minute == 30 && _secondi ==00) accendi(pinSettore5);
if (_hour == 13 && _minute == 40 && _secondi ==00) spegni(pinSettore5);
if (_hour == 13 && _minute == 40 && _secondi ==00) accendi(pinSettore6);
if (_hour == 13 && _minute == 50 && _secondi ==00) spegni(pinSettore6);
if (_hour == 13 && _minute == 50 && _secondi ==00) accendi(pinSettore7);
if (_hour == 14 && _minute == 00 && _secondi ==00) spegni(pinSettore7);
if (_hour == 14 && _minute == 00 && _secondi ==00) accendi(pinSettore8);
if (_hour == 14 && _minute == 10 && _secondi ==00) spegni(pinSettore8);
if (_hour == 14 && _minute == 10 && _secondi ==00) accendi(pinSettore9);
if (_hour == 14 && _minute == 20 && _secondi ==00) spegni(pinSettore9);
if (_hour == 14 && _minute == 20 && _secondi ==00) accendi(pinSettore10);
if (_hour == 14 && _minute == 30 && _secondi ==00) {spegni(pinSettore10); Serial.println("Stop irrigazione");}
if (sera == 1)
if (_hour == 20 && _minute == 00 && _secondi ==00) {accendi(pinSettore1); Serial.println("Start irrigazione");}
if (_hour == 20 && _minute == 30 && _secondi ==00) spegni (pinSettore1);
if (_hour == 20 && _minute == 30 && _secondi ==00) {accendi(pinSettore2); Serial.println("Start settore 2");}
if (_hour == 21 && _minute == 00 && _secondi ==00) spegni (pinSettore2);
if (_hour == 21 && _minute == 00 && _secondi ==00) {accendi(pinSettore4); Serial.println("Start settore 4");}
if (_hour == 21 && _minute == 30 && _secondi ==00) spegni (pinSettore4);
if (_hour == 21 && _minute == 30 && _secondi ==00) {accendi(pinSettore5); Serial.println("Start settore 5");}
if (_hour == 22 && _minute == 00 && _secondi ==00) spegni (pinSettore5);
if (_hour == 22 && _minute == 00 && _secondi ==00) {accendi(pinSettore6); Serial.println("Start settore 6");}
if (_hour == 22 && _minute == 30 && _secondi ==00) spegni (pinSettore6);
if (_hour == 22 && _minute == 30 && _secondi ==00) {accendi(pinSettore7); Serial.println("Start settore 7");}
if (_hour == 23 && _minute == 00 && _secondi ==00) spegni (pinSettore7);
if (_hour == 23 && _minute == 00 && _secondi ==00) {accendi(pinSettore8); Serial.println("Start settore 8");}
if (_hour == 23 && _minute == 30 && _secondi ==00) spegni (pinSettore8);
if (_hour == 23 && _minute == 30 && _secondi ==00) {accendi(pinSettore9); Serial.println("Start settore 9");}
if (_hour == 00 && _minute == 00 && _secondi ==00) spegni (pinSettore9);
if (_hour == 00 && _minute == 00 && _secondi ==00) {accendi(pinSettore10); Serial.println("Start settore 10");}
if (_hour == 00 && _minute == 30 && _secondi ==00) {spegni (pinSettore10); Serial.println("Stop irrigazione");}
if (_hour == 20 && _minute == 00 && _secondi ==00) accendi(pinSettore3); // siepeee insieme a cancello e piscina tubo
if (_hour == 21 && _minute == 00 && _secondi ==00) spegni (pinSettore3);
}// fine loop
void accendi(int zona)
{ digitalWrite( zona, LOW );
void spegni(int zona)
{ digitalWrite( zona, HIGH );
void adesso()
{ DateTime now = RTC.now();
Serial.print("ora attuale ");
Serial.print(now.day(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.year(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println();
}//adesso
This work 1/2 hours after restart to begin…
i don’t understand where is the problem…
An other thing : during thousand tests i tried to set INPUT the pin mode instead OUTPUT and seems work till the end !!
But … this does not turn on the relays… Only OUTPUT turn on the relay. thank you to who help me…
