• Hardware model + communication type: Arduino UNO with Bluetooth module HC-06
• Smartphone OS: Android 6.0.1
• App version: 2.26.4
• Blynk server
• Blynk Library version 0.5.3
Problem: the pull data mechanism no longer works in the Android app when working with Bluetooth classic communication
Create one Button widget on V1
Create one Widget “Value Display Settings” on V2 with 1 sec reading rate
The widget “value display settings” never sends the request to read the value, but it should request V2 every second
Sketch:
#define BLYNK_DEBUG
SoftwareSerial BTSerial(2, 3); // RX, TX
char auth[] = "...";
// Widget Button on V1
BLYNK_WRITE(V1)
BLYNK_PRINT.println("BLYNK_WRITE V1");
// Widget "Value Display Settings" on V2 with 1 sec reading rate
BLYNK_READ(V2)
BLYNK_PRINT.println("BLYNK_READ V2");
int t = 1234;
Blynk.virtualWrite(V2, t);
BLYNK_PRINT.begin(115200);
BLYNK_PRINT.println("Setup started");
BTSerial.begin(9600);
Blynk.begin(BTSerial, auth);
Debug output:
Setup started
[0]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.3 on Arduino Uno
Give Blynk a Github star! => https://github.com/blynkkk/blynk-library
[14] Connecting...
[6014] Connecting...
[12014] Connecting...
[14284] >[02|00|01|00]
[14318] >5fxxxxxxxxxxxxx4b69b1
[14319] Ready
[14319] Free RAM: 1516
[14320] <[00|00|01|00|C8]
[17009] >[14|00|02|00|08]
[17017] >vw[00]1[00]440
BLYNK_WRITE V1
[17221] >[14|00|03|00|06]
[17227] >vw[00]1[00]0
BLYNK_WRITE V1
[17743] >[14|00|04|00|08]
[17753] >vw[00]1[00]440
BLYNK_WRITE V1
[17847] >[14|00|05|00|06]
[17853] >vw[00]1[00]0
BLYNK_WRITE V1
[18310] >[14|00|06|00|08]
[18318] >vw[00]1[00]440
(B.T.W. I discovered this issue during the development of the ESP32 Bluetooth (classic!) Blynk adapter. But I found out that the bug could be reproduced on HC-06)
