#define BLYNK_TEMPLATE_NAME "Soler monitoring system"
#define BLYNK_AUTH_TOKEN "Q6Dj092nraH2Vlxxxx"
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_ADS1X15.h>
#include <BlynkSimpleEsp32.h>
#include <OneWire.h>
// Pin definitions
const int oneWirePin = D3; // OneWire pin for DS18B20
// OLED display
Adafruit_SSD1306 display(128, 64, &Wire);
// ADS1115
Adafruit_ADS1115 ads;
// DS18B20 temperature sensor
OneWire oneWire(oneWirePin);
float voltage =0;
float current =0;
float power =0;
float energy = 0;
float temperature =0;
float saving =0; // cost saving
const float EnergyCost = 7.5;
// Voltage divider resistor values
const float R1 = 560; // 560k
const float R2 = 33; // 33k
const float R3 = 1; // 1K
const float R4 = 2; // 2K
// ACS758 zero-current output voltage ( Offset Voltage)
float OffsetVoltage = 2.5;
// ACS758 current sensor sensitivity
const float sensitivity = 40; // in mV/A
//========================= Variables for wifi server setup =============================
const char* ssid = "ruby";
const char* password = "123456789900";
const char* blynkAuth = "Q6Dj092nraH2VlPxxxxx";
// Initialize the Wi-Fi and Blynk connections
WiFi.begin(ssid, password);
delay(2000);
Serial.print(".");
Serial.println("\nConnected to Wi-Fi");
Blynk.begin(blynkAuth, ssid, password);
// Initialize the OLED display
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.display();
// Initialize the ADS1115
ads.begin();
// Initialize the DS18B20 temperature sensor
sensors.begin();
// Read the raw voltage values from the ADS1115
int16_t voltageRaw = ads.readADC_SingleEnded(0);
int16_t currentRaw = ads.readADC_SingleEnded(1);
// Calculate the voltage values in Volts
float voltageVolts = voltageRaw * (0.1875/1000) ; // 0.1875mV is default Gain
float voltage = voltageVolts * ((R1 + R2) / R2); // Calculate the actual voltage by using the voltage dividers
// Calculate the current values in Amps
float currentVolts = currentRaw * ((R3 + R4) / R4)* (0.1875/1000); // 0.1875mV is default Gain
current = (currentVolts - OffsetVoltage )/(sensitivity / 1000.0) ; // convert voltage into current
// Calculate the power output (P = V * I)
power = voltage * current;
// Calculate energy by integrating power over time
unsigned long currentMillis = millis();
energy += power * (currentMillis - previousMillis) / 3600000; // Energy in Wh
saving = EnergyCost * ( energy /1000 );
// Read the temperature from the DS18B20 sensor
temperature = sensors.getTempCByIndex(0); // temperature in Celsius
//temperature = sensors.getTempFByIndex(0); // temperature in Fahrenheit
//Display the values on the OLED screen
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(10, 10);
display.print(voltage,2);
display.println(" V");
display.setCursor(70, 10);
display.print(current,2);
display.println(" A");
display.setTextSize(2);
display.setCursor(10,25);
display.print(power,2);
display.println(" W");
display.setCursor(10,45);
display.print(energy,2);
display.println(" Wh");
// display.print("T: ");
// display.print(temperature);
// display.println(" C");
display.display();
// ================= Display Data on Blynk App ================================================
// Send the data to Blynk
Blynk.virtualWrite(V0, voltage);
Blynk.virtualWrite(V1, current);
Blynk.virtualWrite(V2, power);
Blynk.virtualWrite(V3, energy/1000);
Blynk.virtualWrite(V4, temperature);
Blynk.virtualWrite(V5, saving);
// Print the values on the Serial Monitor
Serial.print(" Voltage: ");
Serial.print(voltage);
Serial.print("V");
Serial.print(" Current: ");
Serial.print(current);
Serial.print("A");
Serial.print(" Power: ");
Serial.print(power);
Serial.print("W");
Serial.print(" Energy: ");
Serial.print(energy,2);
Serial.print("Wh");
Serial.print(" Savings: ");
Serial.print("Rs.");
Serial.print(saving,2);
Serial.print(" Temp: ");
Serial.print(temperature);
Serial.println("C");
delay(2000);
The circuit works correctly after wifi is connected but after disconnect it does not connect again only it keeps on searching serial print is mentioned below please help us with the project
11:15:28.493 -> Voltage: 4.44V Current: -50.53A Power: -224.20W Energy: -1.53Wh Savings: Rs.-0.01 Temp: -127.00C
11:15:31.460 -> Voltage: 4.37V Current: -50.58A Power: -221.01W Energy: -1.73Wh Savings: Rs.-0.01 Temp: -127.00C
11:15:34.252 -> Voltage: 4.42V Current: -50.58A Power: -223.40W Energy: -1.90Wh Savings: Rs.-0.01 Temp: -127.00C
11:15:37.105 -> [34210] Connecting to blynk.cloud:80
11:15:37.105 -> [34211] Connecting to blynk.cloud:8080
11:15:37.105 -> Voltage: 4.42V Current: -50.58A Power: -223.40W Energy: -2.08Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:39.919 -> Voltage: 4.41V Current: -50.58A Power: -223.23W Energy: -2.25Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:42.744 -> [39857] Connecting to blynk.cloud:80
11:15:42.744 -> [39857] Connecting to blynk.cloud:8080
11:15:42.744 -> Voltage: 4.42V Current: -50.57A Power: -223.37W Energy: -2.43Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:45.541 -> Voltage: 4.41V Current: -50.57A Power: -223.20W Energy: -2.60Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:48.381 -> [45504] Connecting to blynk.cloud:80
11:15:48.381 -> [45504] Connecting to blynk.cloud:8080
11:15:48.381 -> Voltage: 4.42V Current: -50.58A Power: -223.40Energy: -2.78Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:51.208 -> Voltage: 4.42V Current: -50.58A Power: -223.40W Energy: -2.95Wh Savings: Rs.-0.02 Temp: -127.00C
11:15:54.030 -> [51151] Connecting to blynk.cloud:80
11:15:54.030 -> [51151] Connecting to blynk.cloud:8080
after disconnect not connecting to Wi-Fi hotspots
Board xiao_esp32c3
