hi guys, I connected four soil moisture sensors to a 16-channel multiplexer (74hc4067). I’m not getting the raw values as I suppose to, Dry =1024 and wet = 744(my value). While writing this, i found out that BlynkEdgent.run(); is the one causing this.
#define BLYNK_TEMPLATE_ID "TMPL4HxPZsxa"
#define BLYNK_DEVICE_NAME "LED"
#define APP_DEBUG
#include<DHT.h>
#include "BlynkEdgent.h"
#define DHTTYPE DHT22
#define DHTPIN 13 //D7
#define S0 D1
#define S1 D2
#define S2 D3
#define S3 D4
#define SIG A0
//#define pump1 15//D5
DHT dht(DHTPIN, DHTTYPE);
int mois;
int mois1;
int mois2;
int mois3;
//pinMode(pump1, OUTPUT);
BlynkEdgent.begin();
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(SIG, INPUT);
dht.begin();
timer.setInterval(100L,sensors);
//timer.setInterval(100L,readSensor);
digitalWrite(S0,LOW);
digitalWrite(S1,LOW);
int mois = analogRead(SIG);
//mois = map(mois,744, 1024, 0, 100); //744 = wet; 1024= dry
mois = map(mois,1024, 0, 0, 100);
/*if (mois < 20)
digitalWrite(pump1, LOW); //on
else if(mois >85){
digitalWrite(pump1,HIGH); //off
digitalWrite(S0,HIGH); digitalWrite(S1,LOW);
int mois1 = analogRead(SIG);
mois1 = map(mois1,1024, 639, 0, 100);
digitalWrite(S0, LOW); digitalWrite(S1,HIGH);
int mois2 = analogRead(SIG);
mois2 = map(mois2,1024, 639, 0, 100);
digitalWrite(S0,HIGH); digitalWrite(S1,HIGH);
int mois3 = analogRead(SIG);
mois3 = map(mois3,1024, 639, 0, 100);
Serial.print("Sensor 0 : ");Serial.println(mois);
Serial.print("Sensor 1 : ");Serial.println(mois1);
Serial.print("Sensor 2 : ");Serial.println(mois2);
Serial.print("Sensor 3 : ");Serial.println(mois3);
delay(2000);
BlynkEdgent.run();
/*void readSensor(){
Blynk.virtualWrite(V1,mois);
Blynk.virtualWrite(V2,mois1);
Blynk.virtualWrite(V3,mois2);
Blynk.virtualWrite(V4,mois3);
void sensors(){
float h = dht.readHumidity();
if (isnan (h) || isnan (t)) {
Serial.println("Failed to read DHT sensor");
return;
Blynk.virtualWrite(V6,h);
Blynk.virtualWrite(V7,t);
