Hi, there
I have bought this board.
I have success with understanding of DIP switches. But, I am failing to integrate Blynk with this board:
Using this board with Android Blynk app running on Android 9 & 6
I am not able to upload soil moisture sensor data to value display widget or gauge.
I have checked the ESP8266 Serial
It connects to blynk and shows ready for ping.
The problem with this board is I can’t use serial while ESP8266 and Atmega2560 are communicating according to DIP Switches.
Is there any mistake in code or firmware or what? Please guide.
#include <ESP8266_Lib.h>
char auth[] = "tDUJKWT72VJclvEwIk0nTNXX0k_x0sW6";
char ssid[] = "CA Parul Gupta";
char pass[] = "9a346f62b700";
int sensorValue = 0;
int sensorPin = A0;
int sensorValuePercent = 0;
#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void myTimerEvent()
sensorValue = map(sensorValue, 0, 1023, 1023, 0);
sensorValuePercent = (sensorValue / 1023) * 100;
sensorValue = analogRead(sensorPin);
EspSerial.print("\nThe moisture level is");
EspSerial.print(sensorValue);
EspSerial.print("\n");
EspSerial.print(sensorValuePercent);
Blynk.virtualWrite(V5, sensorValue);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
myTimerEvent();
