i am facing wdt error while using esp8266 with blynk. some time when i upload code it work perfectly when i modify it and then upload it gave me wdt error. i try all the possible solution but not solved. i try ESP.wdtDisable(), simpletimer and changed my code many time but it is wastage of time. can anyone tell me why this happen. please tell me as soon as possible
Are you using digital datastreams?….
If not, then it’s most likely something in your sketch - which you haven’t shared.
If you do post the sketch, don’t forget the triple backticks at the beginning and end of the code.
