Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Hello, please I need help, Blynk App sows that was not online yet. below is my NodeMcu Code
char auth[] = "Y12vESUKNP5YEa7pmHwA_fbwGda1fAKB";
char ssid[] = "speeder";
char pass[] = "Billions@";
String myString; // complete message from arduino, which consists of sensors data
char rdata; // received charactors
int firstVal, secondVal,thirdVal; // sensors
int led1,led2,led3,led4,led5,led6;
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
Blynk.virtualWrite(V1, millis() / 1000);
timer.setInterval(1000L,sensorvalue1);
timer.setInterval(1000L,sensorvalue2);
timer.setInterval(1000L,sensorvalue3);
timer.setInterval(1000L,sensorvalue4);
timer.setInterval(1000L,sensorvalue5);
timer.setInterval(1000L,sensorvalue6);
if (Serial.available() == 0 )
if (Serial.available() > 0 )
rdata = Serial.read();
myString = myString+ rdata;
// Serial.print(rdata);
if( rdata == '\n')
Serial.println(myString);
// Serial.println("Rosa");
// new code
String l = getValue(myString, ',', 0);
String m = getValue(myString, ',', 1);
String n = getValue(myString, ',', 2);
String o = getValue(myString, ',', 3);
String p = getValue(myString, ',', 4);
String q = getValue(myString, ',', 5);
// these leds represents the leds used in Blynk application
led1 = l.toInt();
led2 = m.toInt();
led3 = n.toInt();
led4 = o.toInt();
led5 = p.toInt();
led6 = q.toInt();
myString = "";
// end new code
void sensorvalue1()
int sdata = led1;
Blynk.virtualWrite(V10, sdata);
void sensorvalue2()
int sdata = led2;
Blynk.virtualWrite(V11, sdata);
void sensorvalue3()
int sdata = led3;
Blynk.virtualWrite(V12, sdata);
void sensorvalue4()
int sdata = led4;
Blynk.virtualWrite(V13, sdata);
void sensorvalue5()
int sdata = led5;
Blynk.virtualWrite(V14, sdata);
void sensorvalue6()
int sdata = led6;
Blynk.virtualWrite(V15, sdata);
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
the serial monitor shows 255 once a put a toy car near the IR sensor.
