Hello Community!
I am not sure if this is blynk related bit I am working on a Smart Car System and i do not know what pins i should connect to make a communication between my Arduino Board and the NodeMCU R3. I am using blink as my cloud but the color of my led is not changing with the recorded motion by my sensors. If i upload the code my device is coming online though. Kindly help
I am using NodeMCu V3 and Arduino Uno R3
Android OS
Blynk Server
ESP8226 Community Version
My Sketch for Arduino
‘’’ cpp
SoftwareSerial nodemcu(2,3); //Connect NodeMcu to port 2 and 3 of the Arduino Uno
// parking slot1 infrared sensor connected with pin number 4, 5, 6 of arduino
int parking1_slot1_ir_s = 4;
int parking1_slot2_ir_s = 5;
int parking1_slot3_ir_s = 6;
int parking2_slot1_ir_s = 7;
int parking2_slot2_ir_s = 8;
int parking2_slot3_ir_s = 9;
String sensor1;
String sensor2;
String sensor3;
String sensor4;
String sensor5;
String sensor6;
// Complete Data Consisting of Sensor Values
String cdata="";
nodemcu.begin(9600);
pinMode(parking1_slot1_ir_s, INPUT);
pinMode(parking1_slot2_ir_s, INPUT);
pinMode(parking1_slot3_ir_s, INPUT);
pinMode(parking2_slot1_ir_s, INPUT);
pinMode(parking2_slot2_ir_s, INPUT);
pinMode(parking2_slot3_ir_s, INPUT);
p1slot1();
p1slot2();
p1slot3();
p2slot1();
p2slot2();
p2slot3();
//Comma acts as a delimeter
cdata = cdata + sensor1 + "," + sensor2 + "," + sensor3 + ","+ sensor4 + "," + sensor5 + "," + sensor6 + ",";
Serial.println(cdata);
nodemcu.println(cdata);
delay(6000); // 100 milliseconds
digitalWrite(parking1_slot1_ir_s, HIGH);
digitalWrite(parking1_slot2_ir_s, HIGH);
digitalWrite(parking1_slot3_ir_s, HIGH);
digitalWrite(parking2_slot1_ir_s, HIGH);
digitalWrite(parking2_slot2_ir_s, HIGH);
digitalWrite(parking2_slot3_ir_s, HIGH);
//Parking1 Slot1
void p1slot1()
if(digitalRead(parking1_slot1_ir_s) == LOW)
sensor1 = “255”;
delay(200);
if(digitalRead(parking1_slot1_ir_s) == HIGH)
sensor1 = “0”;
delay(200);
// Parking1 Slot 2
void p1slot2()
if(digitalRead(parking1_slot2_ir_s) == LOW)
sensor2 = “255”;
delay(200);
if(digitalRead(parking1_slot2_ir_s) == HIGH)
sensor2 = “0”;
delay(200);
//Parking1 Slot 3
void p1slot3()
if(digitalRead(parking1_slot3_ir_s) == LOW)
sensor3 = “255”;
delay(200);
if(digitalRead(parking1_slot3_ir_s) == HIGH)
sensor3 = “0”;
delay(200);
//Parking2 Slot 1
void p2slot1()
if(digitalRead(parking2_slot1_ir_s) == LOW)
sensor4 = “255”;
delay(200);
if(digitalRead(parking2_slot1_ir_s) == HIGH)
sensor4 = “0”;
delay(200);
// Parking2 Slot 2
void p2slot2()
if(digitalRead(parking2_slot2_ir_s) == LOW)
sensor5 = “255”;
delay(200);
if(digitalRead(parking2_slot2_ir_s) == HIGH)
sensor5 = “0”;
delay(200);
//Parking2 Slot 3
void p2slot3()
if(digitalRead(parking2_slot3_ir_s) == LOW)
sensor6 = “255”;
delay(200);
if(digitalRead(parking2_slot3_ir_s) == HIGH)
sensor6 = “0”;
delay(200);
My sketch for the nodemcu
‘’'cpp
#define BLYNK_TEMPLATE_ID " "
#define BLYNK_DEVICE_NAME " "
#define BLYNK_AUTH_TOKEN " "
// Set password to “” for open networks.
char ssid[] = " ";
char pass[] = " ";
String myString; //complete message from arduino, which consistors of snesors data
char rdata; //received character
int firstVal, secondVal, thirdVal; //sensors
int led1, led2, led3, led4, led5, led6;
//This function sends Arduino’s up time every second to Virtual Pin (1).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void myTimerEvent()
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V1, millis()/1000);
Blynk.begin(auth, ssid, pass, “blynk.cloud”, 80);
//Blynk.begin(auth, ssid, pass, “blynk.cloud”, 80);
timer.setInterval(1000L, sensorValue1);
timer.setInterval(1000L,sensorValue2);
timer.setInterval(1000L,sensorValue3);
timer.setInterval(1000L,sensorvalue4);
timer.setInterval(1000L,sensorvalue5);
timer.setInterval(1000L,sensorvalue6);
if (Serial.available() == 0)
timer.run(); //Initiates BlynkTimer
if (Serial.available() > 0)
rdata = Serial.read();
myString = myString+ rdata;
//Serial.print (rdata);
if ( rdata == '\n')
Serial.println(myString);
//Serial.println("Denis");
//new code
String l = getValue(myString, ‘,’, 0);
String m = getValue(myString, ‘,’, 1);
String n = getValue(myString, ‘,’, 2);
String o = getValue(myString, ‘,’, 3);
String p = getValue(myString, ‘,’, 4);
String q = getValue(myString, ‘,’, 5);
//these leds represents the leds used in Blynk application
led1 = l.toInt();
led2 = m.toInt();
led3 = n.toInt();
led4 = o.toInt();
led5 = p.toInt();
led6 = q.toInt();
myString = “”;
//end code here
void sensorValue1()
int sdata = led1;
Blynk.virtualWrite(V2, sdata);
void sensorValue2()
int sdata = led2;
Blynk.virtualWrite(V3, sdata);
void sensorValue3()
int sdata = led3;
Blynk.virtualWrite(V4, sdata);
void sensorvalue4()
int sdata = led4;
Blynk.virtualWrite(V5, sdata);
void sensorvalue5()
int sdata = led5;
Blynk.virtualWrite(V6, sdata);
void sensorvalue6()
int sdata = led6;
Blynk.virtualWrite(V11, sdata);
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = {0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++){
if (data.charAt(i) == separator || i == maxIndex){
found++;
strIndex[0] = strIndex[1] = 1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : “”;
