Mine too.
@newdos I would still run the sketch I provided but modified for Arduino use, keeping everything else the same. Developers can never have too many logs.
Thereās a tiny chance itās ESP specific but unlikely as you still have the problem in your main sketch. I canāt really see how the basic sketch can work unless you have taken something out of the sketch.
Slider settings min max values are default and mapped or not? As I donāt see receiving 0 value in slider.
Actually in my test they are unmapped but set with min of 16 and max of 30.
Yep.
I see several writes of 16 received by the slider.
The same result for min of 0.
Iāve rechecked that log - seems swith to zero position happens not due to server writes, but somehow in the app. On this week Iāll create a build with more slider logs for this issue, it is unclear at now moment whatās happening.
Thanks Guys @Costas, @BlynkAndroidDev watching this with great interest. Would love to know what is causing the issue and costas I will try and reproduce here using your sketch later today. I have been away and very busy.
Cheers
Kev
Hi @Costas, @BlynkAndroidDev blynk
rather weirdly I have uploaded your sketch to my wemos d1 (retired) and it works fine??? only thing that has changed is I loaded the logging version of the android software to my tablet to try and send logs(which I failed to do) the was up earlier in this thread, so wonder if there is a fix in that version ???
Cheers
kev
@newdos 4 days ago the logging build didnāt have a fix for the ābugā.
What version of Android does your tablet have?
it say 2.13.3 but now it doesnāt have the button to send the logs any more ??? but it did at first !!
Cheers
kev
Not the app version, the Android version of the tablet like 4.4, 5.0, 6.0 etc.
Hi @Costas
Version of my tablet android op is 4.2.2 and kernel is 3.0.36+
Does that help?
Cheers
kev
Hi @Costas
Any news on this yet, or do these type of issues take a while for resolution ?
Cheers
Kev
Hi Guys @Costas and @BlynkAndroidDev
Just wondering if there is a fix anywhere in sight for this yet please ?
Cheers
kev
No, as we need more detailed logs. Iāve forget about this issue, after the next release iāll add here new log build for better slider work logging.
