Slider Widget keeps resetting to 0 on Android only
You have pin 3 in your ESP code.
You can’t have an int of 0.3 and you can’t currently use float’s in the slider for Android.
Hi @Costas
Ok so I have changed this back to a float vrbl (i was experimenting with the int for this to see if it made any difference - it didnt) but why is this relevant to the slider? the slider is on V29 ?
Cheers
kev
@newdos I’m just pointing out some of the bugs in your code.
Declaring an int at 0.3 means the variable will always be 0 (significant number for you) and therefore your Hysteresis will not be working.
Trying to use pins that are not externally exposed on an ESP (pin 3 in your sketch) is very bad form as there is always a chance that the ESP tries to access an internal pin setting etc.
You also have pin 9 declared which is another pin that is not externally exposed on an ESP.
DO NOT RUN YOUR SKETCH ON AN ESP UNTIL YOU HAVE CHANGED IT.
Edit: pin 3 is actually exposed on an ESP but it’s actually the UART Rx pin and normally avoided.
Pins 6 to 11 are not exposed on most ESP’s but I believe there are a few boards that make some of these pins available. Interesting article on what can happen if you accidentally select pin 9 (as per your sketch) https://www.letscontrolit.com/forum/viewtopic.php?t=1462
Hi @Costas
Ok all taken on board. I will modify sketch to use different pins to see if it makes any difference then I will com back to you and let you know the outcome
Cheers
kev
Hi Guys,
Still trying to get to the bottom of this and I have now narrowed it down to a loop in my code that I cant see why it would affect the sliders on V29 and V28. It is this loop that causes the sliders to jump to zero but only on android - void sendStatus - shown below. If I don’t call this loop the sliders works fine. Full code is further up the thread if required.
I cannot see anything wrong with this loop so a little baffled at the moment - hoping extra pairs of eyes can tell me why this loop is causing this ?
Cheers
kev
void sendStatus()
  // has Arduino been reset or just started.
  if (resetFlag == true && year() != 1970)
    resetTimeDate = currentTimeDate;
    Blynk.virtualWrite(V31, currentStatus);
    Blynk.setProperty(V31, "label", String("Current Status:                    SYSTEM RESET at ") + resetTimeDate);
  if (Heat1_Status == 1 && resetFlag == true)   // Runs once following reset/start if Heat is ON.
    startFlag = true;
    resetFlag = false;
  else if (Heat1_Status == 0 && resetFlag == true) // Runs once following Arduino reset/start if heat is OFF.
    stopFlag = true;
    resetFlag = false;
  // Display all the data on the app
  // Have we passed threshold of heat limit? if so turn it off
  if (digitalRead(Heat1_pin) == 1 && startFlag == true) // now OFF, but was on
    // Purpose: To swap between ON and OFF display once heating state change.
    stopTimeDate = currentTimeDate;                                   // Set off time.
    Blynk.setProperty(V31, "color", "#23C48E");   // Green
    Blynk.virtualWrite(V31, String("Heat OFF since ") + stopTimeDate); // Write to app.
    currentStatus = String("Heat OFF since ") + stopTimeDate;
    stopFlag = true;   // Ready flag when heat turns on.
    startFlag = false;// Keep everything locked out until the next cycle.
  else if (digitalRead(Heat1_pin) == 0 && stopFlag == true) // ON, but was off
    startTimeDate = currentTimeDate;
    Blynk.setProperty(V31, "color", "#D3435C");   // Red
    Blynk.virtualWrite(V31, String("Heat ON since ") + startTimeDate);
    currentStatus = String("Heat ON since ") + startTimeDate;
    startFlag = true;
    stopFlag = false;
@newdos I would try deleting V28 to V31 in your project and recreating the widgets in case the system has got confused what virtual pins you selected. After deleting them, logout, turn phone off and then start again with those 4 pins.
OK @Costas will try that and come back to you
Cheers
kev
Hi @Costas
Now I have logged out of the blynk app on my phone I cannot get logged back in. This goes back to the email issues I was having. The app actual says my email address which is my login is not in the blynk database!!! - how can this be ???
Can someone look at this please as it’s doing my head in !!!
Cheers
kev
Hi @Costas think my iphone app was screwed so deleted it and reinstalled it and it has let me back in with my original ID and password so ignore last message.
Cheers
Kev
Hi @Costas,
Ok done what you said and even had to delete the app because of login screw ups. I have now rebuild the widgets and it is exactly the same - works fine on ios but still jumps to zero on android
Over to you!
Cheers
kev
@newdos until I have chance to study all the code in detail can you try and isolate the problem further i.e. comment out some of the if and else parts of the problem section.
Will do @Costas that was my next plan anyway
Will let you know if I find anything further.
Cheers
kev
Hi @Costas,
Not getting much further with this - It is not just the loop I thought it was it is any of them. ie if the simpletimer calls any loop as you are dragging the slider it jumps to zero. I have proven that the more frequently the loop is called the more the slider will do it so my loop that is called every 200 milliseconds really screws it up.
I even commented out the blynk_write(V29) code (my slider in question) to see if it was interaction with this call and the timer, and that proved it was the timer alone, as the slider still did it.
Would you consider this as a bug as it doesn’t do this in ios and consider a fix, or am I going to have try and work the code with simpletimer in a different fashion (haven’t a clue how though!!)?
Cheers
kev
@newdos perhaps go back to one of your earlier basic sketches that was working ok and add a 200ms timer to see if that indicates a Blynk bug.
I know Blynk have recently done some work with SimpleTimer and I think the minimum setting is now 10ms.
I have to say that the Slider widget is very popular and we are not seeing reports from others of the issue you have. That said most people will not have a 200ms timer in their project.
OK @Costas I will look at that an report back.
Meanwhile I also just had a thought - I note the actual Blynktimer states in the docs that it fixes some issues for use with Blynk. Might it be worth trying this library to see if works with the slider ?
Cheers
kev
I was just going to say upgrade to 0.4.7 if you haven’t already.
If you are using latest Blynk library, you are automatically using BlynkTimer.
@Gunner, @Costas
Ah ok guys guess that’s not going to make any difference then as I am already on v0.4.7. So even though I use simpletimer it’s automatically using blynktimer correct ?
Cheers
kev
Hi @Costas, @Gunner
Think I have found the cause. It seems to be caused by calling a void from a timer that has a virtualwrite within the loop
here is a cut down version of the code that runs on arduino
#include<SimpleTimer.h>
int feedback1;            // AC feedback1 variable
int SetPoint1;            // Temp setting for room monitored by DHT22
int AC_Sens1_pin = 3;     // Relay 1 ac sens pin
char auth[] = "xxx";
  Blynk.begin(auth);
  //Lets sync up all the store states for the V pins and load the appropriate variables listed below
  Blynk.syncVirtual(V29);            // SetPoint1
  timer.setInterval(200, AC_detect); // Check if the room is occupied via PIR sensor
void AC_detect()
  feedback1 = digitalRead(AC_Sens1_pin);
  Blynk.virtualWrite(V2, feedback1); // update SWITCH widget state from AC input only if it has changed
BLYNK_WRITE(V29)  // Input from slider in app to set SetPoint1
  SetPoint1 = param.asInt();
  Serial.println(SetPoint1);
If you comment out the line in the AC_detect void that has the Blynk.virtualwrite in it, the slider works fine, put that line back in and it jumps around all over the place!!
I have also tried this with another loop not called so often ie every second - and if it has the virtualwrite in it, it screws up - take it out and its fine
So, I am hoping you guys will accept this a bug (unless you tell me otherwise!!)
Cheers
kev
