@Dmitriy “feature” confirmed with library versions 0.4.6 and 0.4.7 i.e you can’t slide the slider if the slider function contains a virtualWrite.
@newdos good work digging out the feature. You asked in an earlier post how you could fix the issue.
'1. I actually never slide the slider. Might be partly due to the early days when sliding was a definite no, no but also I prefer to “dab” the slider where I think I want to set it at.
or
'2. Set a flag in the slider and then check for the flag outside of the slider function.
This issue is not reproducing on our side, so maybe we still not got smth of it. If it is possible, you could install that logging build and send us logs - so we could check what device is receiving and debug this issue more deeply.
Newdos, its an installation file for a version of Blynk which has a broader logging ability.
You download it on your android and install it. You might need to allow “installations from unknown sources” first.
Then you follow the instructions. So start by downloading the apk from the dropbox link, on your android device and install it.
That is the special logging version of Blynk that contains the ability to send the requested logs. Download it, install it (you may need to uninstall your current Blynk App first,if problems installing logging version.
Run it and do whatever you do to get the slider to do whatever it does, then send the log files.
Perhaps something else I may of found then lol!!! I logged back into my android using facebook and they weren’t there. Logged out and back in manually and low and behold it has reappeared???
