Hello everyone
The raspberry pi mode for Blynk on iOS identifies GPIO 18 as a PWM pin. However, I am using a Raspberry Pi 4 Model B which uses a slightly different pinout, identifying GPIO 12 and 13 as PWM0 and PWM1 respectively. I want a slider on Virtual Pin 7 to control the speed of a Noctua 5V PWM fan from 0 to 255 on my raspberry pi hooked up to gpio 12 or 13. Could anyone please post code for the above situation in Node.js format?
Regards
In fact, the point 6 is about a pwm intensity of a led. If you need it with a servo, just change “pwmWrite” for “servoWrite” taking care of the values in your phone app: 500 to 2400 microseconds for a SG90 (see datasheet) instead of 0 - 180 degrees or values 0 - 255 for 8-bit resolution
