I would like to control a ledstrip with the blynkapp.
I use the doit ESP32 devkit1 as hardware.
But the software doesn’t trigger the BLYNK_WRITE(V24).
Have anyone a solution for that?
http://twitter.com/blynk_app
This example runs directly on ESP32 chip.
Note: This requires ESP32 support package:
https://github.com/espressif/arduino-esp32
Please be sure to select the right ESP32 module
in the Tools -> Board menu!
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "7b0998cf38204daf9c90322bbf1b975c";
char ssid[] = "Labo";
char pass[] = "joyceiseensloeber";
BLYNK_WRITE(V24)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
BLYNK_READ(V24)
int pinValue = 0; // assigning incoming value from pin V1 to a variable
