Hello, I have a project to control rgbww LEDs with esp32 via the Blynk app, my problem comes when I want to adjust the brightness of the cold white led, the slider does nothing to the led.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Blynk.h>
#include <analogWrite.h>
#include <EEPROM.h>
#define r_pri 12
#define g_pri 27
#define b_pri 25
#define c_pri 34
#define w_pri 32
#define r_sec 13
#define g_sec 14
#define b_sec 26
#define c_sec 35
#define w_sec 33
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int rv1;
int gv1;
int bv1;
int pinw;
int pinc;
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8080);
pinMode(r_pri, OUTPUT);
pinMode(g_pri, OUTPUT);
pinMode(b_pri, OUTPUT);
pinMode(c_pri, OUTPUT);
pinMode(w_pri, OUTPUT);
pinMode(r_sec, OUTPUT);
pinMode(g_sec, OUTPUT);
pinMode(b_sec, OUTPUT);
pinMode(c_sec, OUTPUT);
pinMode(w_sec, OUTPUT);
BLYNK_WRITE(V0) // primary color
rv1 = param[0].asInt();
gv1 = param[1].asInt();
bv1 = param[2].asInt();
analogWrite(r_pri, rv1);
analogWrite(g_pri, gv1);
analogWrite(b_pri, bv1);
BLYNK_WRITE(V1) // secondary color
int rv2 = param[0].asInt();
int gv2 = param[1].asInt();
int bv2 = param[2].asInt();
analogWrite(r_sec, rv2);
analogWrite(g_sec, gv2);
analogWrite(b_sec, bv2);
BLYNK_WRITE(V2) // warm white
pinw = param[0].asInt();
analogWrite(w_pri, pinw);
BLYNK_WRITE(V3) // cold white
pinc = param.asInt();
analogWrite(c_pri, pinc);
BLYNK_WRITE(V4) // RGB on/off
int v = param.asInt();
if(v == 0){
analogWrite(r_pri, 0);
analogWrite(g_pri, 0);
analogWrite(b_pri, 0);
}else{
Serial.println(v);
BLYNK_WRITE(V5) // white on/off
if(v == 0){
analogWrite(w_pri, 0);
}else{
Serial.println(v);
