Sketch from here:
http://docs.blynk.cc/#widgets-displays-terminal
takes Particle Photon offline
Used #include <blynk.h> instead of #include <BlynkSimpleEthernet.h>
Could this be the reason for Photon going offline?
Code used:
#include <blynk.h>
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
You can send/receive any data using WidgetTerminal object.
App project setup:
Terminal widget attached to Virtual Pin V1
char auth[] = "f9d2f28cce96411a8850ebf11c26112f";
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V3);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V3)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
// Send it back
terminal.println("You said:");
terminal.println(param.asStr());
// Ensure everything is sent
terminal.flush();
Blynk.begin(auth);
for(int i=1;i<=25;i++)
terminal.println();
terminal.flush();
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.println(F("Type 'Marco' and get a reply, or type"));
terminal.println(F("anything else and get it printed back."));
terminal.flush();
Code resposible for this is:
terminal.write(param.getBuffer(), param.getLength());
Once this code is executed, Particle Photon shows status: Offline, in 10 seconds (Breathing Green).
What could be causing this issue?
This works:
// Send it back
But what's wrong with the code from docs?
