I’m using the SimpleTimer like so: timer.setTimer(1000, toggleLed, 3); but nothing happens, I tried to add a print but it doesn’t print it.
“toggleLed” has a signature of void foo(); and I included #include <SimpleTimer.h>.
@Yamashiro if you are using Blynk library 0.4.7 or later, which you really should be, then BlynkTimer is already in the library i.e. you don’t need
Where in the Arduino guide https://playground.arduino.cc/Code/SimpleTimer did you see the syntax you are using?
If you look closely you will see the timer has to be configured as an integer so it can automatically be deleted after it has run x times.
@Yamashiro actually it doesn’t need to be defined as an integer which means you have a bug elsewhere in your code. Paste a formatted sketch if you need further assitance.
I have Blynk 0.4.8.
I just replaced the SimpleTimer with BlynkTimer timer; and both timer.setTimeout(1000, turnControlLedOff); and timer.setTimer(100, ledToggle, 3); don’t work.
It’s from:
What can cause it not to work?
The function works for me as per the Arduino docs.
What do you have in ledToggle function?
Here is a minimal example where the timeout doesn’t work:
#include <BlynkSimpleEsp8266_SSL.h>
// control led
BLYNK_WRITE(V0)
if(pinValue == 1){
digitalWrite(LED_BUILTIN, LOW);
Serial.println("got value");
timer.setTimeout(1000, foo);
void foo(){
Serial.println("foo");
pinMode(BUILTIN_LED, OUTPUT); // set onboard LED as output
digitalWrite(BUILTIN_LED, HIGH);
// to avoid delay() function!
I only see “got value” and not “foo” in the serial monitor.
