Device: ESP32
Communication: wifi
Purpose: switch on/off two LEDs with app and web interface.
Phone: android 12.0
Blynk server region: India
Blynk Library verion: 1.3.2
Managed to get the device online. Web interface as well as app interface are in sync with each other.
- The intention is to switch on and off LEDs connected to D26 and D33 on the ESP32 board.
- Button 1 doesn’t seem to be working.
- Button 2 switches on an internal blue LED.
- Serial monitor keeps printing message. " : 2 is reserved" which O am not printing intentionally.
- I am using Datastream 1 and 2.
- See the images attached.
- Why won’t it correctly operate D26 and D33 on the board?
Code:
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "..." // details are correctly given in the code
// #define BLYNK_DEVICE_NAME "..." // details are correctly given in the code
#define BLYNK_TEMPLATE_NAME "..." // details are correctly given in the code
#define BLYNK_AUTH_TOKEN "..." // details are correctly given in the code
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
//Home Wifi Network
char ssid[] = "..."; // details are correctly given in the code
char pass[] = "..."; // details are correctly given in the code
#define led1_pin 26
#define led2_pin 33
int led1_state = 0;
int led2_state = 0;
#define button1_vpin V1
#define button2_vpin V2
BLYNK_CONNECTED() {
Blynk.syncVirtual(button1_vpin);
Blynk.syncVirtual(button2_vpin);
BLYNK_WRITE(button1_vpin) {
led1_state = param.asInt();
digitalWrite(led1_pin, led1_state);
Blynk.virtualWrite(led1_pin,led1_state);
Serial.print("ledpin1 =");
Serial.print(led1_pin);
Serial.print(" : ");
Serial.println(led1_state);
BLYNK_WRITE(button2_vpin) {
led2_state = param.asInt();
digitalWrite(led2_pin, led2_state);
Blynk.virtualWrite(led2_pin,led2_state);
Serial.print("ledpin2 =");
Serial.print(led2_pin);
Serial.println(led2_state);
pinMode(led1_pin, OUTPUT);
pinMode(led2_pin, OUTPUT);
listen_push_buttons();
void listen_push_buttons(){
delay(200);
Blynk.virtualWrite(button1_vpin, led1_state);
delay(200);
Blynk.virtualWrite(button2_vpin, led2_state);
