Here’s my twist on @hagay project…long press manual on and off buttons, long press timer on and off buttons, numeric input widget for manual timer activation and styled button indicating current status of system ie. timers on or off, activation time etc color change for solenoid activation.
You can add your own colour by using the appropriate hex code with your code.
Hello hagay, I’m just modify and testing your code at entry 57, with my relays. It’s very nice, it does exactly
what I need.
What do you think about introducing something to get a daily/weekly history of past actions?
I was thinking about “Superchart” widget… just to make sure that my irrigation started regularly.
Terminal widget applied to hagay’s code. Much like serial print, terminal print sends messages to bunk app. I set ‘‘tis up to do time stamps so I can monitor my system.
Terminal window scrolls. Very easy to integrate into Hagay”s code. Secondary benefit is the widget header is written to by code so I used it to display cpu time and date. This gives me the connection health status with out taking up a lot of screen space.
Side note: the terminal display also revealed what appears to be random events wher all 4 relays get set to offf. I think this is happening if the ESP 8266 chip gets disconnected from the server and then reconnects? The only other time I see this is when my device first boots up.
When a relay turns on using the timer input widgets, it prints the calculated duration based on start time and end time. Hagay already built this into the code for serial print messages. So, all I had to do was copy and paste the pieces to into my terminal print message for it to deliver the desired message to my Blynk app.
I think I’m experiencing something similar whereby the system resets for an unknown reason. I thought it may have something to do with my mods to @hagay code. Haven’t had much time to look into it yet.
Thanks Arizona for the feedback.
My intention with the new code was to have a “future proof” code for all my next projects (not sure it is but at least I am enjoying
it). I can understand why you decided to remain with the old code.
For the max duration issue I forgot to reset the max_duration_sec array so I think if you add :
max_duration_sec[i] = 864000;
befor :
active_duration_sec[i][TIME_CNT] = 0;
it should solve it.
From what I know you can add the superchart widget to your app without any change to the code and just assign it with the required gpio.
The only problem with this is that it will not track the device status if the device loose connection.
I had some similar reset behaviour when I had too many serial printouts.
I think the blynk use a watchdog timer and when I had too many printouts it did not return to the void loop in time.
Setting serial speed to 115200 and reducing printouts solved it for me.
It may be that you have too many terminal printouts at once and see the same behaviour.
Ok thanks for the update. Very much appreciated…I’ll adjust and give feedback.
Hagay—once again thank you. I have both serial prints running and terminal prints. On my device I had to set serial print to 9600 else I only get random ASCII characters. The terminal print uses WiFi but I suspect your assessment is accurate and I am not returning to the loop in time —specially since I added in more prints and slowed down my serial print speed. I will investigate further.
thanks for the suggest.
I’m testing your code with #define SCHEDULER_CNT 7
#define TIME_CNT 1.
I realize that if I use more than 4 SCHEDULER_CNT It works fine from V0 to V4 and does not from 5 to 7.
did u test your code using more than 4?
it seams to work on my initial test with SCHEDULER_CNT 7 and TIME_CNT 1
did you manage to make it work ?
maybe check you initialize task_gpio_pins and task_gpio_default ?
also check the issue with the max duration ? please add max_duration_sec initialization as in post 67
Hello hagay, I checked several time without success, if u will have a time to have a look…
Here my code and UI.
Thanks in advance.
/* Blynk SCHEDULER
* This code implements a parametric scheduler to activate a task
* at specific times and specific days .
* The system operates at resolution of minuets.
* Each scheduler can be assigned one task (i.e. turn on/off a gpio ...).
* The user can parametrize the number of schedulers.
* The user can parametrize the number of timers assigned to each scheduler.
* Each timer can be configured (from the app) to activate/deactivate
* the task at specific start/end time and days of week
* Each task can also be activated immediately and turned off after a
* configurable default time per scheduler (from the app).
* If end time is not given the task will be deactivated
* after the scheduler default time.
* Each scheduler can be configured (from app) with a max duration.
* If when timer activates a task the max duration is smaller than
* the configured task duration then the task is activated for max duration.
* If max duration is smaller than 2min it is ignored.
* The system can be disabled for a configurable (from app) number of days.
* When in sleep mode all active tasks and all schedulers are turned off.
* If number of days is 0 all current active tasks will be turned off
* If number of days is 1 all tasks and all schedulers will be
* turned off until midnight of today.
* If number of days is 2 all tasks and all schedulers will be
* turned off until midnight of next day. ...
* The system can also be put in sleep (from app) .
* When in sleep mode all active tasks are turned off. Schedulers continue working
* but will not activate tasks. Once out of sleep mode tasks are turned on if they
* ware expected to be active without the sleep mode.
* if number of days is 0 the sleep button has no effect.
* if number of days is 1 the sleep mode continue until midnight.
* if number of days is 2 the sleep mode continue until midnight next day....
//#include <ESP8266mDNS.h>
//#include <WiFiUdp.h>
//#include <ArduinoOTA.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
// system configuration section
// The following section contains code that should be changed
// by user to match the exact system needs.
#define WIFI_LED 16
// define parameters for number of schedulers and number of timers
#define TIME_CNT 1
// This system uses gpio on of as tasks.
// The number of used gpio per task is given by task_gpio_pins array
//byte task_gpio_pins[] = {12 , 5 , 4 , 15}; // number of gpio to be used as task control
//byte task_gpio_pins[] = {13, 12 , 14, 0, 5, 2, 4}; // number of gpio to be used as task control
//byte task_gpio_pins[] = { 2, 4, 14, 0, 5, 13, 12}; // number of gpio to be used as task control
byte task_gpio_pins[] = {13,12,14,0,4,2,16}; // number of gpio to be used as task control
// The default value of the gpio for task off is given by task_gpio_default.
// (used for gpio negative polarity)
//bool task_gpio_default[] = {LOW,HIGH,LOW,HIGH};
bool task_gpio_default[] = {HIGH,HIGH,HIGH,HIGH};
char auth[] = "";
char ssid[] = "TIM-A-PT";
char pass[] = "DbEmNLTr";
// task activation function
// this is an abstraction layer for activating task
// currently only simple activation of gpio but user can change this
void task_on_off(bool task_state, char scheduler_num){
bool gpio_val = task_state^task_gpio_default[scheduler_num];
digitalWrite(task_gpio_pins[scheduler_num],gpio_val);
if (task_state)
Serial.println(String("Turn On Task: ") + (int)scheduler_num);
Serial.println(String("Turn Off Task: ") + (int)scheduler_num);
// end system configuration section //
// The following defines will automatically assign virtual pins //
// The first SCHEDULER_CNT*TIME_CNT virtual pins are assigned for time inputs //
// where virtual pins 0..TIME_CNT-1 are for scheduler 0 //
// pins TIME_CNT..2*TIME_CNT-1 for scheduler 1 ... //
// The following SCHEDULER_CNT pins are used for default duration sliders //
// The following SCHEDULER_CNT pins are used for immediate activation button //
// The following SCHEDULER_CNT pinst are used for maximum duration slider //
// Pin ( SCHEDULER_CNT*(TIME_CNT+3) ) +3 used for system sleep button //
// Pin ( SCHEDULER_CNT*(TIME_CNT+3) ) +4 used for system disable button //
// Pin ( SCHEDULER_CNT*(TIME_CNT+3) ) +5 used for slider of number of days //
// to disable system //
// User must ensure that number of used Virtual pins will not exceed 127 //
// So the following rule must be kept when selecting SCHEDULER_CNT and TIME_CNT//
// SCHEDULER_CNT*(TIME_CNT+3) < 123 //
// define time inputs Virtual Pin (Time Input Widget) for timer 0 of scheduler 0
#define VP_SWCH0_TIME0 V0
// define activation duration Virtual Pin (Slider Widget) for Scheduler 0 (V7)v7/..V13
#define VP_ACTV_DUR_SCHD0 (VP_SWCH0_TIME0+(TIME_CNT*SCHEDULER_CNT))
// define immidiate activation Virtual Pin (Button Widget) for Scheduler 0 (V14)V14/..V20
#define VP_IMMD_ACTV_SCHD0 (VP_ACTV_DUR_SCHD0+SCHEDULER_CNT)
// define max duration Virtual Pin (Slider Widget) Scheduler 0 (V21) V21/..V27
#define VP_MAX_DUR_SCHD0 (VP_IMMD_ACTV_SCHD0+SCHEDULER_CNT)
// define disable system input and number of days to disable input
#define VP_SLEEP_SYS (VP_MAX_DUR_SCHD0+SCHEDULER_CNT+4) /// (v21+7+4) V32
#define VP_DISBL_SYS (VP_MAX_DUR_SCHD0+SCHEDULER_CNT+5) /// (V33)
#define VP_DISBL_DAYS (VP_DISBL_SYS+1) /// (V34)
// maximum possible time in seconds using uint32_t (this is at year 2106)
#define TIME_MAX 0xFFFFFFFF
// time input arrays
int start_time_sec[SCHEDULER_CNT][TIME_CNT]; // Array of TIME_CNT timers per scheduler containing
// minuet in day for scheduler activation
bool weekdays[SCHEDULER_CNT][TIME_CNT][7]; // Array of 7 days (Sunday is day 0 ) for each time
int32_t active_duration_sec[SCHEDULER_CNT][TIME_CNT+1];// duration per time input (in sec) additional "timer"
// is used to save the default active duration
int32_t max_duration_sec[SCHEDULER_CNT]; // max duration per scheduler (in sec)
bool system_sleep_mode = false; // current sleep mode
uint32_t active_end_time_sec[SCHEDULER_CNT]; // current end time (in sec from 1970) per active scheduler
// if scheduler is not active (no active task) this == TIME_MAX
uint32_t max_end_time_sec[SCHEDULER_CNT]; // current end time due to max active time time (in sec from 1970)
// per active scheduler
// If scheduler is not active or max time =< 2 min this == TIME_MAX
// saves id of main timer
uint8_t main_timer_id;
// system disable timer
uint8_t disable_timer_id = 32; // When system is disabled or at sleep a timer is set to wake
// the system disable_timer_id saves this timer ID
// system disable days
int32_t system_disable_days_sec; // VP_DISBL_DAYS defines days to disable/sleep the system (including today) given in sec
// timer object declaration
BlynkTimer SystemTimer; // for calling activetoday and for turning off sleep/disable modes
// this code use Real Time Clock widget in the blynk app to keep the clock updated from net
WidgetRTC rtc;
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
Blynk.syncAll();
// End of Sleep and Disable Modes //
// (They will probably not be used together so if one ends the other must end too) //
void sleep_disable_mode_off()
// iterate over all schedulers and re reactivate tasks if needed (sleep mode).
for (int scheduler_cnt = 0; scheduler_cnt< SCHEDULER_CNT; scheduler_cnt++)
if(active_end_time_sec[scheduler_cnt]!=TIME_MAX) task_on_off(HIGH, scheduler_cnt);
// enable main timer (only if in disable mode)
SystemTimer.enable(main_timer_id);
// set disable and sleep buttons to off
Blynk.virtualWrite(VP_DISBL_SYS,0);
Blynk.virtualWrite(VP_SLEEP_SYS,0);
// set disable timer id to 32 to prevent disabling system timer by mistake
SystemTimer.deleteTimer(disable_timer_id);
Serial.println(String("Sleep/Disable mode off"));
////// BLYNK_WRITE_DEFAULT ///////
// BLYNK_WRITE_DEFAULT enables defining configurable number of schedulers and
// time inputs without changing the code (only change defines)
// BLYNK_WRITE_DEFAULT takes any write to virtual pin and parse it using request.pin
BLYNK_WRITE_DEFAULT() {
uint8_t pin = request.pin; // Which exactly pin is handled?
// DISABLE DAYS SLIDER INPUT //
if (pin == VP_DISBL_DAYS) system_disable_days_sec = param.asInt()*86400; // V33
// SYSTEM DISABLE/SLEEP BUTTONS INPUT //
else if((pin == VP_DISBL_SYS )|(pin == VP_SLEEP_SYS)){ // V31 & V32
if (param.asInt()!=0){
String currentDate = String(day()) + "\\" + month() + "\\" + year();
if (pin == VP_SLEEP_SYS){
system_sleep_mode = true;
// turn off all tasks (do not disable the schedulers )
for (int task_cnt = 0; task_cnt< SCHEDULER_CNT; task_cnt++)
task_on_off(LOW, task_cnt);
// print current data on VP_SLEEP_SYS button
Blynk.setProperty(VP_SLEEP_SYS, "onLabel", currentDate);
else{
// disable main time tick
SystemTimer.disable(main_timer_id);
// turn off all active schedulers
Serial.println(String("Disable all"));
scheduler_turn_off(scheduler_cnt);
Blynk.setProperty(VP_DISBL_SYS, "onLabel", currentDate);
// if disable days is 0 then set nowseconds to -1 to prevent timer with negative duration
int32_t nowseconds = -1;
if (system_disable_days_sec!=0)
nowseconds = elapsedSecsToday(now());
// create a timer to wake the system up after system_disable_days_sec are over
SystemTimer.deleteTimer(disable_timer_id); // make sure no disable timer is active
disable_timer_id = SystemTimer.setTimeout(1000*(system_disable_days_sec-nowseconds),sleep_disable_mode_off);
else {// if system is manually out of seep mode delete disable timer and enable schedulers
sleep_disable_mode_off();
// MAX DURATION SLIDER INPUT //
else if (pin >= VP_MAX_DUR_SCHD0) { //V24..V27
if (pin < VP_MAX_DUR_SCHD0+SCHEDULER_CNT){
if(param.asInt()>2)
max_duration_sec[pin-VP_MAX_DUR_SCHD0] = param.asInt()*60;
max_duration_sec[pin-VP_MAX_DUR_SCHD0] = 864000; // set to 10 days is equivalent to not setting max duration
// SCHEDULER IMMEDIATE TASK ACTIVATION BUTTON INPUT //
else if (pin >= VP_IMMD_ACTV_SCHD0) { //V20..V23
if ( pin <(VP_IMMD_ACTV_SCHD0+SCHEDULER_CNT) ) {
if (param.asInt()==0)
scheduler_turn_off(pin-VP_IMMD_ACTV_SCHD0);
scheduler_turn_on(pin-VP_IMMD_ACTV_SCHD0,TIME_CNT); // immediate turn on using duration from slider
// DEFAULT ACTIVE DURATION SLIDER INPUT //
else if (pin >= VP_ACTV_DUR_SCHD0) { //V16..V19
// default duration is written in extra "timer"
if (pin <VP_ACTV_DUR_SCHD0+SCHEDULER_CNT) active_duration_sec[pin-VP_ACTV_DUR_SCHD0][TIME_CNT] = param.asInt()*60;
// TIME INPUT //
else if (pin >= VP_SWCH0_TIME0) { // V0..V15
int scheduler_num = (pin-VP_SWCH0_TIME0)/TIME_CNT;
int time_num = (pin-VP_SWCH0_TIME0)%TIME_CNT;
if ((scheduler_num<SCHEDULER_CNT) &( time_num<TIME_CNT)) {
TimeInputParam t(param); // convert to time input parameter
// Process start time
start_time_sec[scheduler_num][time_num]= -1; // start_time_sec of -1 indicate no start time is set (will never match current time)
if (t.hasStartTime())
Serial.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute() + ":" + t.getStartSecond());
Serial.println(String("Start in sec: ") + param[0].asLong() + String(" for scheduler") + scheduler_num + String(" time_no: ") + time_num);
start_time_sec[scheduler_num][time_num]=param[0].asLong();
// check if end time is received convert and save it as day time in seconds //
active_duration_sec[scheduler_num][time_num] = -1;
if (t.hasStopTime())
Serial.println(String("Stop: ") + t.getStopHour() + ":" + t.getStopMinute() + ":" + t.getStopSecond());
Serial.println(String("Stop duration: ") + (param[1].asLong() -param[0].asLong()));
active_duration_sec[scheduler_num][time_num] = (param[1].asLong()-param[0].asLong());
// if end time is smaller than start time this means end time is at next day
if (active_duration_sec[scheduler_num][time_num]<=0)
active_duration_sec[scheduler_num][time_num] = 86400+active_duration_sec[scheduler_num][time_num];
// Process weekdays (1. Mon, 2. Tue, 3. Wed, ...) //
for (int i = 1; i <= 7; i++) {
weekdays[scheduler_num][time_num][(i%7)] = t.isWeekdaySelected(i);
if (t.isWeekdaySelected(i))
Serial.println(String("Day ") + i + " is selected");
Serial.println();
////// END OF BLYNK_WRITE_DEFAULT ///////
// Handle Scheduler events (from app or from timers ) //
// handle scheduler ON
void scheduler_turn_on(byte scheduler_num , byte time_no){
uint32_t now_abs_time = now();
// turn on the task
if (!system_sleep_mode) task_on_off(HIGH, scheduler_num);
// if stop time is not defined use the duration from slider
if(active_duration_sec[scheduler_num][time_no]>=0)
active_end_time_sec[scheduler_num] = now_abs_time+active_duration_sec[scheduler_num][time_no];
active_end_time_sec[scheduler_num] = now_abs_time+active_duration_sec[scheduler_num][TIME_CNT];
// max_end_time_sec is changed only if it was not previously set
if (max_end_time_sec[scheduler_num]==TIME_MAX)
max_end_time_sec[scheduler_num]=now_abs_time+max_duration_sec[scheduler_num];
// create time as string to print on activation button
char Time_print[10];
sprintf(Time_print, "%02d:%02d", hour(), minute());
// set button on and write the activation time on the button
Blynk.setProperty(VP_IMMD_ACTV_SCHD0+scheduler_num, "onLabel", String(Time_print));
Blynk.virtualWrite(VP_IMMD_ACTV_SCHD0+scheduler_num,1);
Serial.println(String("turn ON scheduler: ") + scheduler_num + String(" Until : ") + max_end_time_sec[scheduler_num]);
// handle scheduler OFF
void scheduler_turn_off(char scheduler_num ){
// set task off
task_on_off(LOW, scheduler_num);
// delete associated timer
active_end_time_sec[scheduler_num] = TIME_MAX;
max_end_time_sec[scheduler_num] = TIME_MAX;
Serial.println(String("turn OFF scheduler: ") + scheduler_num);
// reset button
Blynk.virtualWrite(scheduler_num + VP_IMMD_ACTV_SCHD0,0);
//// the following function is called every 10 seconds by a timer ////
//// the function checks if a start time is reached and if yes it will call ////
//// the scheduler_turn_on function (to turn on the scheduler and ////
//// set timer for turning off scheduler) ////
uint32_t last_abs_min = 0; // saves the last minute that activetoday was started at
// this is later used to ensure activetoday will not be started twice at the same minute
void activetoday(){ // check if schedule #1 should run today
uint32_t now_abs_sec = now(); // time in seconds from 1970
// set wifi led if no connection
if(Blynk.connected())
digitalWrite(WIFI_LED,HIGH);
digitalWrite(WIFI_LED,LOW);
if(year() != 1970){ // if RTC was not started do nothing
uint32_t now_sec = elapsedSecsToday(now_abs_sec);
uint32_t now_abs_min = now_abs_sec/60;
for (uint8_t scheduler_cnt = 0; scheduler_cnt< SCHEDULER_CNT; scheduler_cnt++) {
// scheduler itteration
for (uint8_t timer_cnt = 0; timer_cnt< TIME_CNT; timer_cnt++) {
uint8_t tmp_day = 0x01<<weekday();
// Timer itteration
if (now_abs_min != last_abs_min) {
if ((weekdays[scheduler_cnt][timer_cnt][weekday()-1]==true) &
((now_sec >= start_time_sec[scheduler_cnt][timer_cnt]) & (now_sec < (start_time_sec[scheduler_cnt][timer_cnt])+60)) ){
// activation
scheduler_turn_on(scheduler_cnt,timer_cnt);
// De activation (per scheduler)
if ((now_abs_sec >= active_end_time_sec[scheduler_cnt])|
(now_abs_sec >= max_end_time_sec[scheduler_cnt]) ){
last_abs_min = now_abs_min; // save last used min
// BLYNK
// reset tasks and system variables
for (int i = 0; i<SCHEDULER_CNT ; i++){
pinMode(task_gpio_pins[i], OUTPUT); // set output pins
task_on_off(LOW,i ); // turn tasks off
for (int j = 0; j<TIME_CNT ; j++) { // reset timer parameters
active_duration_sec[i][j] = -1; // duration of -1 indicate no stop time is set
start_time_sec[i][j]= -1; // start_time_sec of -1 indicate no start time is set
active_duration_sec[i][TIME_CNT] = 0; // this is the duration from the slider
active_end_time_sec[i] = TIME_MAX; // TIME_MAX indicate scheduler is not active
max_end_time_sec[i] = TIME_MAX; // TIME_MAX indicate scheduler is not active
pinMode(WIFI_LED, OUTPUT);
// active today is called every 10 secondes
// if scheduler is manualy activated the scheduler may be active for up to extra 10 seconds
main_timer_id = SystemTimer.setInterval(10000L, activetoday);
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
// ArduinoOTA.setHostname("myesp8266");
// No authentication by default
// ArduinoOTA.setPassword((const char *)"Hay6t7r)");
// ArduinoOTA.onStart([]() {
// Serial.println("Start");
// ArduinoOTA.onEnd([]() {
// Serial.println("\nEnd");
// ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
// Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
// ArduinoOTA.onError([](ota_error_t error) {
// Serial.printf("Error[%u]: ", error);
// if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
// else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
// else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
// else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
// else if (error == OTA_END_ERROR) Serial.println("End Failed");
// ArduinoOTA.begin();
// ArduinoOTA.handle();
SystemTimer.run();
you need to change :
to :
bool task_gpio_default[] = {HIGH,HIGH,HIGH,HIGH,HIGH,HIGH,HIGH};
and also add :
befor :
Yesss! Thank you very much.
if cut internet. Timer can work or not
yes timer run without internet
I can add time_no for scheduler_turn_off function such as
scheduler_turn_off(byte scheduler_num , byte time_no )
If you look carefully you will see that the scheduler_turn_off is called out of the time_no loop.
the information for which time_no was used to turn on is not saved. You could add an array to save time_no.
it will look something like :
///////////////////////////////////// // activation //////////////////////////////////// scheduler_turn_on(scheduler_cnt,timer_cnt); **saved_time_cnt[scheduler_cnt] = timer_cnt;** } } } /////////////////////////////////// // De activation (per scheduler) ////////////////////////////////// if ((now_abs_sec >= active_end_time_sec[scheduler_cnt])| (now_abs_sec >= max_end_time_sec[scheduler_cnt]) ){ scheduler_turn_off(scheduler_cnt , saved_time_cnt[scheduler_cnt] ); } }
