im making a project that allow me to monitoring sensor data from the sim900 module to the blynk app with a display value widget, and allow me too to control a valve that can interrupt the water flow on a tube.
My problem is that i cant see the values of the sensor through the app, i dont know why. i leave the code below.
thanks for helping me.
http://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :)
// Select your modem:
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "LBmPtYO54b-7irK3H5cP2iJB4L8O6Arw";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "m2mco.tigo.com";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
BLYNK_CONNECTED() {
volatile int NumPulsos;
const int sensorPin= 2;
float factor_conversion=7.11;
float volumen=0;
long dt=0;
long t0=0;
byte sensorInterrupt = 0;
void ContarPulsos ()
NumPulsos++;
int ObtenerFrecuecia()
int frecuencia;
NumPulsos = 0;
interrupts();
noInterrupts();
frecuencia=NumPulsos;
return frecuencia;
void sendSensor()
float frecuencia=ObtenerFrecuecia();
float caudal_L_m=frecuencia/factor_conversion;
dt=millis()-t0;
t0=millis();
volumen=volumen+(caudal_L_m/60)*(dt/1000);
Serial.print ("Caudal: ");
Serial.print (caudal_L_m,3);
Serial.print ("L/min\tVolumen: ");
Serial.print (volumen,3);
Serial.println (" L");
Blynk.virtualWrite(V4, caudal_L_m);
Blynk.virtualWrite(V5, volumen);
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
digitalWrite(9, HIGH); // Descomentar para activar la alimentación de la tarjeta por Software
digitalWrite(9, LOW);
delay (5000);
// Set GSM module baud rate
SerialAT.begin(19200);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
modem.simUnlock("1234");
pinMode(sensorPin, INPUT);
attachInterrupt(digitalPinToInterrupt(2), ContarPulsos,RISING);
t0=millis();
You need to call function void sendSensor() periodically using BlynkTimer. Timer interval must be much larger than 1000ms because of delay(1000) was called in ObtenerFrecuecia() if you still use that function.
it didnt worked, the modem tried to connect but it doesnt work. but with my code the modem can make de connection. i dont know what might be the problem with your code.
i modified the code this way, changing the baud rate of the software serieal to 9600, and comment the serial1 for the arduino mega, because i am using the arduino uno.
char user[] = "";
char pass[] = "";
volatile int pulseCount;
#define SENSOR_PIN 2
float factor_conversion = 7.11;
float volume = 0;
long deltaTime = 0;
long startTime = 0;
// 10s
#define READ_SENSOR_INTERVAL_MS 10000
BLYNK_CONNECTED()
void pulseCounter ()
pulseCount++;
void sendSensor()
static float frequency;
static float caudal_L_m;
noInterrupts();
frequency = pulseCount;
pulseCount = 0;
interrupts();
caudal_L_m = frequency / factor_conversion;
deltaTime = millis() - startTime;
startTime = millis();
volume = volume + (caudal_L_m / 60) * (deltaTime / 1000);
Serial.print (caudal_L_m, 3);
Serial.print ("L/min\tvolume: ");
Serial.print (volume, 3);
Blynk.virtualWrite(V5, volume);
digitalWrite(9, HIGH); // Uncomment to activate card power by Software
delay (5000);
delay(3000);
modem.restart();
pinMode(SENSOR_PIN, INPUT);
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN), pulseCounter, RISING);
timer.setInterval(READ_SENSOR_INTERVAL_MS, sendSensor);
That’s good you know where to modify.
I had to assume you’re using Mega as you didn’t tell anything about the board.
You also have to reformat your posted code with ``` like you did in the first post. Otherwise you’ll get blamed and posted code deleted by @PeteKnight.
Nobody in the forum knows how to help with so little info such as the code isn’t work yet. It might be because of the software, hardware, wiring, power, board, etc.
Even we just recently know the type of board you’re running is UNO.
You need to add more debug display in strategic locations in the code to know exactly where / when, then post the terminal debug output, hopefully we here have more info.
