SIM900 Bonsai Irrigation system - Multiple Blynk Recconections
Hello everyone!!
I built an irrigation system for my bonsai collection using an Arduino UNO + SIM900 shield which acts over 2 solenoid valves using blynk server. Blynk library version is 0.6.1.
Blynk runs ok, but it disconnects and reconnects aproximately each 12 hours, and I am struggling to find the error.
Now, in summer the irrigation should be aprox. each 5 hours during 1 minute meanwhile the sun is up, then I need 2 timers per valve/bonsai zone.
To set the timers, I simply used several Timer widget related with a timer dedicated vitual pin. I added a led widget just to know the status of valves.
Some times this lost of connections occurred while watering and the close valve instrucction did not arrive to the system. The next day I found my bonsai overflooded.
To avoid this, I included Blynk.connected function as a safe interlock position runned every 5 min.
This is the complete code.
Thanks in advance for your support.
// Select your modem:
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "orangeworld";
char user[] = "orange";
char pass[] = "orange";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
BlynkTimer timer; // Create a Timer object called "timer"!
//Valves Pin definition
#define pinMesa 6
#define pinTroncos 5
//SIM SHIELD SWICTH ON
  pinMode(9,OUTPUT);
  digitalWrite(9,HIGH);
  digitalWrite(9,LOW);
  delay(5000);
  //PULL_UP RELAYS
  pinMode(pinMesa,OUTPUT);
  digitalWrite(pinMesa,HIGH);
  pinMode(pinTroncos,OUTPUT);
  digitalWrite(pinTroncos,HIGH);
  Serial.begin(19200);
  // Set GSM module baud rate
  SerialAT.begin(19200);
  delay(3000);
  modem.restart();
  delay(5000);
  // Unlock your SIM card with a PIN
  modem.simUnlock("");
  timer.setInterval(30000L, conexion);
  timer.run(); // BlynkTimer is working...
//TIMERS MESA
BLYNK_WRITE(V1){ // Timer1
  int flagMesa = param.asInt(); //Timer 1 status reception
  if (flagMesa == 1){
    digitalWrite(pinMesa,LOW); //Opens Valve and water
    Blynk.virtualWrite(V7,255); //app Led On
  else{
    digitalWrite(pinMesa,HIGH); //Valve closes and no watering
    Blynk.virtualWrite(V7,0); //app Led Off
BLYNK_WRITE(V2){ // Timer2
  int flagMesa = param.asInt(); //Recibimos el status del timer 2
  if (flagMesa == 1){
    digitalWrite(pinMesa,LOW); //Opens Valve and watering
  else{
    digitalWrite(pinMesa,HIGH); // Valve closes and no watering
BLYNK_WRITE(V3){ // Timer3
  int flagMesa = param.asInt();  //Recibimos el status del timer 3
  if (flagMesa == 1){
    digitalWrite(pinMesa,LOW); //Abre la válvula y riega
  else{
    digitalWrite(pinMesa,HIGH); // Cierra la válvula y no riega
//TIMERS TRONCOS
BLYNK_WRITE(V4){ // Timer4
  int flagTroncos = param.asInt(); //Recibimos el status del timer 4
  if (flagTroncos == 1){
    digitalWrite(pinTroncos,LOW); //Abre la válvula y riega
    Blynk.virtualWrite(V8,255);
  else{
    digitalWrite(pinTroncos,HIGH); // Cierra la válvula y no riega
    Blynk.virtualWrite(V8,0);
BLYNK_WRITE(V5){ // Timer5
  int flagTroncos = param.asInt(); //Recibimos el status del timer 5
  else{
BLYNK_WRITE(V6){ // Timer6
  int flagTroncos = param.asInt(); //Recibimos el status del timer 6
  else{
    digitalWrite(pinTroncos,HIGH); //Cierra la válvula y no riega
BLYNK_WRITE(V9){ // MANUAL CONTROL Zone 1
  int flagMesa = param.asInt(); //Button status
  if (flagMesa == 1){
    digitalWrite(pinMesa,LOW); //Open the valve and watering
  else{
BLYNK_WRITE(V10){ // MANUAL CONTROL Zone 2
  int flagTroncos = param.asInt(); //Recibimos el status del boton manual
  else{
// SAFE POSSITION INTERLOCK. ALL VALVES CLOSED.
void conexion(){
  bool conectado = Blynk.connected();
  if(conectado == 0){
It would be nice to see some pinMode declarations in your void setup, but other than that nothing leaps out at me.
Could it be a power supply issue? The SIM900 needs a good stable power supply that can deliver plenty of current.
Thanks Pete.
Yes, I will implement pinMode instructions for sure.
I have a dedicated 12V 1,5A power supply for the SIM900 Shield apart from Arduino power supply. I also checked the signal power, and it is good.
