777
July 16, 2019, 5:07am
1
I am sending USSD to *100# to get prepaid simcard balance, TinyGsmclient library has function .sendUSSD(), and its return empty string after use, any ideas how to use it?
#include <Arduino.h>
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
char auth[] = "XXX";
char apn[] = "internet";
char user[] = "";
char pass[] = "";
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
WidgetTerminal terminal(V1);
String cache = "";
BLYNK_WRITE(V1)
if (String("tili") == param.asString())
terminal.println(cache);
terminal.flush();
SerialAT.begin(9600);
delay(3000);
modem.restart();
Blynk.config(modem, auth, "XXX", 80);
modem.simUnlock("1234");
Blynk.connectNetwork(apn, user, pass);
cache = modem.sendUSSD("*100#");
Serial.println(cache);
Perhaps you could try with a basic example from TinyGSM library ( there is AllFunctions.ino example in the package where modem.sendUSSD() has been used) and this way verify if it works with your modem/operator.
777
July 16, 2019, 9:51am
3
I spend some time to figure out,
in library function
String sendUSSD(const String& code) {
sendAT(GF("+CMGF=1"));
waitResponse();
sendAT(GF("+CSCS=\"HEX\""));
waitResponse();
sendAT(GF("+CUSD=1,\""), code, GF("\""));
if (waitResponse() != 1) {
return "";
if (waitResponse(10000L, GF(GSM_NL "+CUSD:")) != 1) {
return "";
stream.readStringUntil('"');
String hex = stream.readStringUntil('"');
stream.readStringUntil(',');
int dcs = stream.readStringUntil('\n').toInt();
if (dcs == 15) {
return TinyGsmDecodeHex8bit(hex);
} else if (dcs == 72) {
return TinyGsmDecodeHex16bit(hex);
return hex;
So my operator use GSM, not HEX, and at the end of message digit 15, HEX decoder must be disable.
String sendUSSD(const String& code, const String& format){//format: GSM,UCS2,HEX,IRA,PCCP,PCDN,8859-1
waitResponse();
sendAT(GF("+CSCS=\""), format, GF("\""));
waitResponse();
return "";
return "";
if (dcs == 15 && format == "HEX") {
} else if (dcs == 72 && format == "HEX") {
return hex;
I am done @vshymanskyy
