my device is: arduino uno is connected to sim800l arduino GND pin to sim800l GND pin Arduino D2 to sim800l TX arduino D3 pin to sim800l RX. i am using Li 3.7V for sim800l power supply. to arduino uno i have connected soil moisture sensor AO to arduino A0, vcc to arduino 5V and GND to GND.
ESP32, Arduino, Raspberry Pi and the likes over the Internet.
You can easily build mobile and web interfaces for any
Downloads, docs, tutorials: https://www.blynk.io
Sketch generator: https://examples.blynk.cc
Blynk community: https://community.blynk.cc
Follow us: https://www.fb.com/blynkapp
https://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :)
/* Fill in information from Blynk Device Info here */
//#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
//#define BLYNK_TEMPLATE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "YourAPN";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(BLYNK_AUTH_TOKEN, modem, apn, user, pass);
i am using this example to connect to blynk but:
22:13:31.439 -> /___/ v1.2.0 on Arduino Uno
22:13:31.473 ->
22:13:31.473 -> #StandWithUkraine https://bit.ly/swua
22:13:31.539 ->
22:13:31.539 ->
22:13:31.539 -> [14457] Modem init...
22:13:41.843 -> [24795] Cannot init
22:13:54.939 -> Initializing modem...
